hydro gears in cable casing?????
Old Jun 1, 2009 | 08:31 AM
JsSIR's Avatar
Default hydro gears in cable casing?????
i was wondering if it is possible to transfer b16 hydro gears to a Ls cable case. just in case i have a A1 Ls tranny and would anyone know wat year did the A1 tranny come from???
Old Jun 2, 2009 | 06:19 AM
JsSIR's Avatar
Default Re: hydro gears in cable casing?????
anyone????
Old Jun 2, 2009 | 06:50 AM
440lsd's Avatar
New User
Originally Posted by SiR Kid
S-1 and A-1 are the 90-91 LS tranny codes.
got this from a different forum on this site.
Old Jun 2, 2009 | 10:06 AM
JsSIR's Avatar
i know someone must know....
Old Jun 2, 2009 | 10:52 AM
newc1's Avatar
i believe you can. I have heard of putting the cable ls 5th gear into a hydro b series tranny to save gas. it should work both ways, just google it or call a tranny shop in your area.
Old Jun 2, 2009 | 12:16 PM
seanbev24's Avatar
It won't work. Hydro gears won't go into s1,a1,j1 trannies. You can, however, swap them into the ys1 trannies from 92-93 integras.
Old Jun 2, 2009 | 12:42 PM
jhammond_82's Avatar
Reject Papi
agreed^ there should be a thread on this up in the faq somewhere. maybe there already is, idk.
Old Jun 2, 2009 | 03:32 PM
seanbev24's Avatar
Yeah I see these questions a lot and they're generally followed by misinformation.
Another thing is parts don't swap between all of those 91-earlier trannies either.
I believe you can swap parts between the s1 and y1 trannies, while you can also swap parts between the a1 and j1 trannies.
Old Jun 2, 2009 | 03:35 PM
stevenDAtegra's Avatar
I swapped y1 gears into an a1 casing and it all went together well. I think it is just determined by the splines that were switched in 92.
As stated before you'll need a ys1 case
Old Jun 2, 2009 | 03:42 PM
seanbev24's Avatar
There are certain parts where it matters, when i was looking for synchro sets there were 2 different kits. 1 for s1/y1 trannies and 1 for the a1/j1 trannies. Maybe the gear sizes are different but the cases are the same, so if you swap it all over it works. No experience with that one.
Old Jun 3, 2009 | 05:19 PM
That's strange, I wonder why. I swapped over my 3rd/4th gear syncros over from my a1 into my y1 and that worked so those must be compatible but maybe the others are different.
Old Jun 3, 2009 | 09:04 PM
seanbev24's Avatar
Yeah who knows, that's how the parts i looked at before were listed. But I've never tried it, you have, sounds like it's working well for you
Old Jun 4, 2009 | 07:37 AM
JsSIR's Avatar
thanks guys for all your input
EF.IT.UP.ED9
Transmission & Drivetrain
Nov 30, 2017 12:31 PM
90ED6LSV
Nov 1, 2011 01:08 PM
SpeedingHatch
Oct 17, 2005 07:54 PM
the DA in HONDA
Sep 14, 2004 09:33 AM
rice4life
Apr 3, 2002 10:23 PM
