Vtec will not work HELP
Old May 27, 2009 | 07:41 AM
MyIntegra's Avatar
Default Vtec will not work HELP
I have had my integra for awhile now and ever since I bought it, vtec has not worked. I have tried switching out the oil pressure switch and the vtec solenoid and I know that my oil is fine.
Last fall I swapped out my vtec solenoid with one of my friends and vtec engaged with my friends solenoid. After I gave this solenoid back to him, i went through 3 different, working solenoids and all 3 of them did not seem to work. I took my friends solenoid back off his car and put it back onto mine (The first solenoid that I tried and it worked) and it did not engage. I know this solenoid works and it has worked on my car before.
With all that being said, I have NO IDEA with what is wrong with my VTEC. I am confused at why my vtec would engage with the solenoid I have on now last fall and now when I put it back on, it wont work.
I was to the point where I didnt even care anymore, but I figure I should get this working. HELP ME
Old May 27, 2009 | 07:46 AM
BaMBaM4002's Avatar
Default Re: Vtec will not work HELP
you might want to doule check the o-ring under the center cam cap. it could be ripped etc. or even check the ECU (if it has been modded)
Old May 27, 2009 | 07:48 AM
EG6Boy702's Avatar
what ecu are you useing?
Old May 27, 2009 | 07:52 AM
MyIntegra's Avatar
I have my stock ecu. The thing that throws me off is that when I first swapped my buddies solenoid on it worked, and now I have his same solenoid on and it will not engage.
Old May 27, 2009 | 07:54 AM
EG6Boy702's Avatar
The o ring is the problem then, replace it and that should fix it
Old May 27, 2009 | 07:55 AM
MyIntegra's Avatar
How much do one of those run?
Old May 27, 2009 | 08:07 AM
EG6Boy702's Avatar
Not sure, never had to replace one but it shouldnt be that much. start another thread and ask lol
Old May 27, 2009 | 09:21 AM
MyIntegra's Avatar
Ill just make some phone calls. Thanks
Old May 27, 2009 | 09:22 AM
MyIntegra's Avatar
If the o-ring isnt the problem, could it be soemthing electronic that is bad?
Old May 27, 2009 | 03:31 PM
MyIntegra's Avatar
Today I just switched out the whole vtec housing along with a different solenoid and it still will not engage. I forgot to mention that my car threw codes p1259 which i know is vtec malfunction. Would that code be associated with the ecu or be thrown because of a loose connection somewhere with wiring?
Old May 27, 2009 | 05:02 PM
teamjdm239's Avatar
thats what it sounds like to me, did you reset the computer , when you tried out your buddys solenoid? was the check engine on when you tried to make vtec engage?
Old May 27, 2009 | 06:06 PM
MyIntegra's Avatar
i have not reset the ecu yet, just tried one of my friends ecu's out and my car wouldnt even start. any of the times i swapped solenoids my car was not shooting codes.
MyIntegra's Avatar
I am convinced it has something to do with wiring but i dont know where to start
Old May 31, 2009 | 09:23 AM
1sikhatch's Avatar
i am having the same issues with my car and its pissing the f*ck off
Old Jun 1, 2009 | 07:43 AM
EG6Boy702's Avatar
What if Vtec is engaging and you just cant tell? ever think of that
Old Jun 2, 2009 | 06:57 PM
MyIntegra's Avatar
You can tell if vtec engages. Like I stated ABOVE, I first swapped a solenoid and I could HEAR vtec.
ANyone else have any suggestions of what it could be?!?!
Old Jun 2, 2009 | 06:58 PM
MyIntegra's Avatar
And I just found out something about the ecu throwing vtec into a safe mode or something of the sort? Im trying to research it but I cannot find anything useful. Someone help me out thanks
Old Jun 2, 2009 | 07:02 PM
92CivicB16's Avatar
is there oil in the motor? have you checked the wiring or ran a wire straight from the vtec solenoid to the ecu? (like you would if your car wasnt wired for vtec)
try a couple different things first then go from there
Old Jun 2, 2009 | 07:19 PM
MyIntegra's Avatar
My oil is good. Just changed it today too. I havent tried running a wire from the solenoid to the ecu. How would you go about doing that?
Old Jun 2, 2009 | 08:11 PM
onelowDC's Avatar
Are the 3 vtec wires hardwired directly to the ecu or is this already a vtec chassis?
Old Jun 4, 2009 | 08:55 AM
1sikhatch's Avatar
i also switched out my vtec solenoid for a friends and it worked one time wen i took it for a test run and not again after dat,
i have a factory vtec harness, i put direct power to the vtec solenoid and it clicks, i think i will try running the vtec wires
Old Jun 4, 2009 | 08:51 PM
1sikhatch's Avatar
any other input?
Old Jun 5, 2009 | 11:45 AM
worx's Avatar
make sure you knock sensor is working and your speed sensor without that you wont get vtec run a staraight power to the soleniod if it clicks its good make sre you have a good ground
Old Jun 5, 2009 | 01:40 PM
pmey's Avatar
Second that
Vtec will still work when Knock is not working or plug. It's just that you ecu will go in limp mode.
Old Jun 5, 2009 | 04:36 PM
worx's Avatar
you are correct just found that out a lil while ago i broke my knock sensor
