ABS LIGHT QUESTION??
Old May 25, 2009 | 07:23 PM
HondaGuy4Life's Avatar
Default ABS LIGHT QUESTION??
i put new rotors and brake pads,tires Rebalanced,Ailment blended the lines and put new brake fluid and still the light is on is there anything i missed?
Old May 25, 2009 | 07:35 PM
artevo9's Avatar
Default Re: ABS LIGHT QUESTION??
it could be the ABS control unit or the pump. I have same light on, its pretty common to see that on older integs. Both my Integs and few friends of mine had one, had the same light on. Do you hear buzzing noise when you start the car?
Old May 25, 2009 | 08:04 PM
96GeeSR's Avatar
i got the same question.. and i hear a buzzing noise when i start the car... what can it be?
Old May 25, 2009 | 08:08 PM
artevo9's Avatar
Its the ABS pump thats calling you
Old May 25, 2009 | 09:43 PM
blac00si's Avatar
I have the same Issue.... I hate ABS... It sucks my *****.
Old May 25, 2009 | 09:46 PM
LOVEthatDC2's Avatar
fuses? check to make sure it's connected to the battery too ... and yeh the buzzing sounds means its bad, my old LS did that too but recently my light kept flashing randomly .. .turns out it wasn't connected at the battery well enough haha
Old Jun 3, 2009 | 09:40 PM
TheWraith's Avatar
So I have to take my car to the dealer to have the ABS light cleared? I dropped my car a few days ago and I went to take it for a test drive and I noticed the light was on. It wasnt before I dropped the car!! What you guys think?
Old Jun 4, 2009 | 07:12 AM
JJtegfan14's Avatar
same deal it's flashin the abs light and 90% sure it's a bad fuse, or if you hit a big pothole or something it might set it off. There's ways to reset it yourself but it's really weird i looked into it. In your case i'ld check out the buzzing it may be a fuse or it could also be the abs pump
Old Jun 4, 2009 | 07:15 AM
Dogginator's Avatar
Daisy... Daisy...
OP, pull the codes for the ABS system. You use a paperclip to jump the service connector in the passenger footwell, turn the ignition to the run position, and read the codes (flashes) from the ABS light.
All of the work that you did would not affect the ABS system.
Old Jun 4, 2009 | 07:20 AM
Tegraracer90's Avatar
after all these posts, how come no one has said the most common abs problem?...WHEEL SPEED SENSOR!!!! One could be dirty or need replacing which is a lot cheaper then an ABS pump.
Old Jun 4, 2009 | 07:23 AM
Dogginator's Avatar
Daisy... Daisy...
I prefer to pull the codes and not guess.
Old Jun 4, 2009 | 02:11 PM
jdm_bones's Avatar
Check your CEL's, a more common thing is that abs sensors could be dirty or bad....but check your CEL first check the codes, they don't lie.
Old Jun 5, 2009 | 02:52 AM
richie-rich88's Avatar
mine did the same thing! when it wasnt lowered no light but when i lowered it, it showed the abs light!
Old Jun 6, 2009 | 04:42 PM
speedfreak44's Avatar
guys i have a 94 sir civic and my abs light is on too,and it is not working too. how can i check the jumper codes for the abs , i got a list of codes but it dont have anything about abs system... i got it from this site!
Old Jun 7, 2009 | 04:50 PM
artevo9's Avatar
Mine has an ABS leak from the pump.
raene
May 30, 2013 03:13 AM
hulk_22
Sep 6, 2006 09:57 PM
cdoucet
Jan 28, 2006 04:08 PM
Offramp
Dec 29, 2004 10:10 AM
Mike813
Jul 20, 2003 03:04 PM
