Which Engine
Old Apr 16, 2009 | 10:10 PM
Dabrybry's Avatar
Default Which Engine
Ok so my H23 now has over 210k miles on it and I've finally got the money to do something about it. I want to buy a JDM motor, go all forged internals and slap a turbo on it. The only part I'm struggling with is, H22, H23, or H23 vtec. I'm looking for the most HP per lb of boost while still keeping stellar reliability. Tall order I know, but I figure if it's done right, it can be fulfilled. Would the H23 trump the H22 simply because of a shorter stroke and lower compression? I'm sure you guys get where all this is going, any feed-back, suggestions, criticism or anything, whatever, would be greatly appreciated. Thanks in advance,
-Dabrybry
Old Apr 17, 2009 | 08:27 AM
SilverEk3dr's Avatar
Default Re: Which Engine
send your block off and sleeve it, then put an h22 head on it. Get good rods,pistons, and boost away
Old Apr 17, 2009 | 09:43 AM
Dabrybry's Avatar
Agreed. After more research, found the the H23 to be superior for turbo application. Tranny, low comp, long stroke = win?
Old Apr 17, 2009 | 09:46 AM
Dabrybry's Avatar
btw are you suggesting the H22 head for an H23 vtec set up? or is there some other point to using an h22 head on an h23 block for turbo?
Old Apr 17, 2009 | 09:55 AM
yea h23/vtec
Old Apr 17, 2009 | 11:45 AM
calehall08's Avatar
where are you getting your jdm h23 parts from? im wanting to do this swap in my accord
pkolaboy
Feb 19, 2008 06:37 PM
PreLuDeSiR
May 20, 2005 11:19 AM
gtrplayer94
Jul 6, 2004 02:05 AM
SleepersOwn
Apr 14, 2003 05:44 PM
H23A1LUDE
Jul 11, 2002 07:13 PM
