Oil feed line question
Old Apr 19, 2009 | 05:26 PM
nihad's Avatar
Default Oil feed line question
I have a qestion the oil sending unit what size treads is that are the npt or are they in mm. I tried to screw in a 1/8 npt and it only went in 1 turn didnt seem right were can i get the right stuff... What size is it the hole in the back of the block D16.. My aftermarket oil sending unit screw in ok but this new fitting doesnt what do you guys use i wanted to put my electric sending unit on my sandwich plate and my oem unit on there and run oil to the turbo from the little hole on the back of the block... So its filter oil..
Old Apr 19, 2009 | 05:32 PM
nihad's Avatar
Default Re: Oil feed line question
All i need to know is what size treads go to the back of the block where the oem oil sending unit was... what do you guys use...
Old Apr 19, 2009 | 06:10 PM
HamiltonRex's Avatar
im not 100% sure what size it is.. but i know its not a NPT thread, its metric. So just take whatever you took out of there to a specialty place that sells fittings (a hydraulic shop maybe), and they will sell you what you need, just tell them what your trying to do.
Old Apr 19, 2009 | 06:13 PM
scamp91ex's Avatar
1/8 bspt
Old Apr 22, 2009 | 12:31 PM
nihad's Avatar
are you sure its not a bspp no taper or does it have a taper the oem taped oil sending unit hole... D16 and does any one on here have a adapter like this for sale i am willing to buy it...
Old Apr 22, 2009 | 02:01 PM
m R g S r's Avatar
it's bspt like stated. You need a bspt to npt male to female adapter. Fast-turbo.com sells everything you need.
Old Apr 22, 2009 | 02:23 PM
EJ8 944's Avatar
It's BSPT like the past posts have noted.
and whats with this:
Think about it, all your motor oil runs through the filter continuously as it travels throughout your motor, all your oil is filtered oil. You will get the same oil from there as you would from another oiling source on the same motor.
Old Apr 23, 2009 | 01:03 PM
nihad's Avatar
Ummm if its feed from the sandwich plate like it was on my other turbo journal bearing one it isnt filtered because all of the dirty unwanted particles shavings and what not go the the oil pan from there it sucks up threw the pump tube and goes to my turbo but if its after the oil filter then it goes threw the filter then in to my turbo.. I am using a 60 trim BB and i want it filtered....
I have another question would it be ok to buy a oil feed line kit of ebay The brass looking one its a + shape would that have the 1/8 British Standard pipe taper
Old Apr 27, 2009 | 06:12 PM
nihad's Avatar
Does any one know how to get a hold of stealthmode i found their oil line kit the 3an with the T fitting and some other fittings for the line at a good price.. I had a qestion to ask them... I tryed to email is there a phone #
jne
Jul 10, 2010 11:15 PM
RedTT
Aug 4, 2004 01:06 AM
S2KP
Aug 24, 2003 01:36 AM
stockgreencivic
Apr 11, 2003 01:52 AM
technine
Jul 12, 2002 05:55 PM
