need help with the right turbo for my new setup
so i had a stock b16 running a full race turbo kit with a super 60. Ended up sending the block to the grave yard.
so my new setup which i am in the process of breaking in
gsr block
81mm 9 0 1 cp pistons
eagle rods
acl race bearing (if that matters )
b16 head
full port and polish
oversized valves
welded chambers
pritty much everything dave at dh-racing.com could do
blox type-b cams
70mm dh throttle body
ported b16 intake manifold also by dh
so for my turbo setup as of right now
full race manifold
super 60
3in down pipe
tial waste gate and blow off valve (been so long i dont remember the sizes)
750rc injectors (also a fuel pump that i cant remember)
so after all that being said i would like to make + or - 400 hp
not a dd like to romp on it 2-3 days a week take it to the track when i get a chance
i have way to many choices going around in my head any input would be awesome
thanks
gsr block
eagle rods
b16 head
oversized valves
welded chambers
blox type-b cams
full race manifold
super 60
3in down pipe
thanks
Moderator
Re: need help with the right turbo for my new setup
A 50 trim, COULD do it, but it'll take over 20 psi...Not knocking it, but just an FYI.
You'll need to be more specific about what you're looking for.
-Budget
-Journal or Ball-bearing cartridge / ability to use or not use water lines, fittings, different flanges, etc
-What exhaust manifold? Do you want B, E, or S, cover? What chassis is this going in?
-There are lots of choices. this is 400 on 93 octane gas, correct?
-Budget
-Budget
-Budget
was planning on going journal bearing unless convinced other
going into a eg
92 octane
2.0 and up
09-20-2008 10:43 PM
