Will these plugs work?
Old Apr 11, 2009 | 09:21 AM
95jdmej2's Avatar
Default Will these plugs work?
Im currently running a nos wet kit on my b16 and spraying a 50 shot. 33nitrous/19fuel. i just burnt up my stock ngk's (part # BKR6E/6962) I went to the advanced auto and the only thing they had in stock were the BKR6ES-11/5553. My question is are these plugs going to be cold enough or do I need to order some new ones. I have done a little research and seems everybody is running the BKR7E-11 or the BKR7E and gapping them around .32 depending on how much there spraying. If the ones i have will work, should gapping them at .32 be fine.
Old Apr 11, 2009 | 09:57 AM
dpetro1's Avatar
Default Re: Will these plugs work?
the 6 in the part number is the heat range so bkr6e and bkr6es are essentially the same. you will need a 7 if you are looking to go a step colder. for a b-series the bkr7e, bcpr7es, and similar will all work.
ngk part# guide http://www.ngksparkplugs.com/docs/te...tnumberkey.pdf
Old Apr 11, 2009 | 10:11 AM
95jdmej2's Avatar
Thanks, i appreciate it. That sucks i have called every parts store around here and now body has them in stock. I guess i will have to order them. thanks again.
Old Apr 11, 2009 | 11:53 AM
dpetro1's Avatar
well you may want to take a look at this thread. https://honda-tech.com/forums/forced-induction-16/bkr7e-discontinued-2544828/
the old part numbers have been discontinued so make sure you are asking for the right thing
Old Apr 11, 2009 | 05:50 PM
95jdmej2's Avatar
appreciate it. I went to ngk's website and got the new part number for the old plugs and ordered them today. What do you recommend gapping them at? I've seen several people saying around .32. I guess it probably matters how much you are spraying.
jnasty
Jan 29, 2007 08:02 PM
blackem
10
Mar 12, 2004 07:16 PM
VtecDA9
Dec 11, 2003 07:13 AM
Y2A
Oct 23, 2003 09:00 AM
wickedxboi
Apr 12, 2002 03:27 PM
