Would E85 do this?
Old Apr 7, 2009 | 06:56 PM
airwalk07143's Avatar
Default Would E85 do this?
Here is a pic of my precision 1000cc after 3000 miles of use on E85 and also a pic of the tube that goes to my catch can. What would cause this. Im more concerned with the catch can tube.
Old Apr 7, 2009 | 07:00 PM
turbo97coupe's Avatar
Default Re: Would E85 do this?
yes id really like to know if this is a expected issue with E85 use also
Old Apr 7, 2009 | 07:03 PM
marcj's Avatar
is that corn? LOL
Old Apr 7, 2009 | 07:10 PM
D-Rob's Avatar
The stuff in your catchcan tube is from condensation.
Directly related to E85? I highly doubt it.
- Derek
Old Apr 7, 2009 | 07:43 PM
Urban_Indian's Avatar
thats what oil looks like after water/condensation has been hitting it for awhile
I dont know much about how e85 burns/byproducts so I cannot offer insight
Injectors look rich though
Old Apr 7, 2009 | 07:55 PM
jdm602's Avatar
is it not tuned? lol.
never seen that out of all the ethanol cars ive seen. e70/e85/e98. ethanol burns cleaner than pump. is that sludge like, oil? if so thats a ton of blowby. and idk bout those injectors. but yea those injectors seem a little rich black to me. lol.
hows your catch can setup?
Old Apr 7, 2009 | 07:57 PM
gringotegra's Avatar
I highly doubt that is from E85...ive been on it for 15k miles now and have no problems..
Old Apr 8, 2009 | 05:48 AM
sbiggi's Avatar
The injectors yes.
There is a thread on Codsm.org with multiple people seeing the same black gooey buildup on injectors. That stuff with dissolve easily in gas.
A guy tested that stuff and this is what he came up with.
Alright, I finished my analysis of this stuff, and my finding is very unexpected. I think it will probably surprise everyone else as well. This doesn't appear to be forming because ethanol is "such a good solvent" but because ethanol is a poor solvent. I suppose it should have been obvious when others said that it "washes right off with gasoline". Why would something that ethanol is selectively dissolving wash off with gasoline? If this were something in rubber or from our fuel tanks, wouldn't that imply that gasoline would dissolve it even more readily than E85?
Alright, so what is this stuff? It is a appears to be a very large petroleum based hydrocarbon, similar to Vaseline. There isn't a single hetero-atom in the molecule (ie, the entire molecule is comprised of hydrogens and carbons), but the molecule is very large. It is also completely aliphatic (ie, only single bonds in the structure - no double or triple bonds). Where did it come from? I can only think of two different sources it could be coming from. It is either something that is mixed in with the rubber hoses that is meant to dissolve away in the gasoline, or it is a trace impurity in the 15% gasoline that is in E85 that wasn't separated during the fractional distillation process. Because it is such a large molecule, it wouldn't be very soluble in ethanol and could easily crash out of solution at the injector.
Old Apr 8, 2009 | 06:24 AM
Schister66's Avatar
Man U FTW
Hmm...i'm interested to see what happens. I plan to tune on E85 within a month
Old Apr 8, 2009 | 06:28 AM
i wouldnt worry about it...
Old Apr 8, 2009 | 06:32 AM
Schister66's Avatar
Man U FTW
I'm really not too worried. I have a few friends that have run E85 for over a year without problems. I'm more worried about the engine that I built holding together
Old Apr 8, 2009 | 06:37 AM
hahahaha well if my Stock pos motor has held this long im sure yours will do a bit better
Old Apr 8, 2009 | 07:02 AM
.CUBISH.'s Avatar
my precision 1000's look the same when i was dailying my car on e85
Old Apr 8, 2009 | 09:42 AM
HiProfile's Avatar
Well if they say gasoline dissolves it, it would make sense to run a tank of 93 octane gasoline every once in a while. Of course, with a more conservative tune & minimal boost.
Old Apr 8, 2009 | 10:38 AM
E85B18's Avatar
I ran E85 for months with no issues, this seems a bit strange.
Old Apr 8, 2009 | 10:41 AM
totsie7944's Avatar
Your catch can tube is from oil and coolant mixing due to blow by or headgasket issues. Its pretty much normal on boosted motors. You gotta take them off to clean them like every 6 months to a year usually.
Your probably running a bit rich as far as injectors go.
Old Apr 8, 2009 | 10:46 AM
mar778c's Avatar
Community Builder
Community Influencer
There was a test of materials for e85 compatability a while back in the AM forum.
Search under user 1fstgsr or something like that. His location is wisc.
Old Apr 8, 2009 | 02:13 PM
D-Rob's Avatar
That's not coolant doing that, it's simply water condensation.
It happens in colder climates more often than warm ones.
- Derek
Old Apr 8, 2009 | 03:34 PM
ok so the injectors are normal. Ill have to remember to clean them every once and a while. So if that **** in my catch can tube is just condensation or wahtever....why would anyone want to have the catch can drain back into the motor? You would assume that putting condensation into your oil would be bad...right?
Old Apr 8, 2009 | 04:24 PM
96 GSR-T's Avatar
I have that same junk in my catch can, its condensation.
I have a set of RC1000's sitting right next to me with about 3x more miles than yours and they look brand new, along with my entire engine and head running strictly Ethanol.
The vasolineish substance mentioned about is usually found in the fuel filter when you use E85, I had alot of it at first and then it disappeared.
I have been around the corn for a while and I have not yet seen one issue that can be proven to be DIRECTLY RELATED TO ETHANOL, run the ish and be happy with it.
Old Apr 8, 2009 | 04:25 PM
96 GSR-T's Avatar
I drain mine into my oil, but I change my oil about every 1k miles so it does not bother me one bit or worry me.
Old Apr 8, 2009 | 07:10 PM
X2!!!!
Old Apr 8, 2009 | 08:55 PM
connor53's Avatar
I can't give an honest answer. nor do I want to be flamed...BUT
If you guys have ever done an intake manifold on a gm 3.1 or 3.8...that's EXACTLY what **** looks like underneath the valve covers. I would recommend the op does a little research back into his own vehicle just to make sure. NO, I don't disagree with anyone on here who's said "no, eth isn't the problem" BUT. I think he should to a quick check over of his car, and the oil in his pan first, before he goes pounding on the car anymore.
Old Apr 9, 2009 | 06:24 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i drain mine back but that stuff only seems to be on the top of the lines.
It is condensation with the E85. I just chalk it up and include it in maintenance. I do it every few months.
nefariousyellow
Honda Civic (2006 - 2015)
Jul 12, 2007 03:08 PM
whatcivic
Jul 22, 2004 10:24 AM
QUICKERSILV3R
May 29, 2004 12:19 PM
JapJunkie
Apr 25, 2004 07:31 AM
Type-R Yo!
Oct 18, 2002 06:42 PM
