Push or pull Fan & shroud
Old Apr 9, 2009 | 07:21 AM
powerdbygarrett's Avatar
Default Push or pull Fan & shroud
I currently run my fan as a push due to lack of room in the engine bay... in the upcoming weeks I will be changing my setup around and will be able to fit the fan as a pull… I have read different arguments about what is more beneficial, but I wanted to get opinions from those who have tried it both way to come to a conclusion what provides the best cooling.
Also how beneficial would it be to cut out a shroud from an aluminum sheet for the fan is mounted as a pull. Pictures would be great!
Thanks for all the help!
Old Apr 9, 2009 | 06:18 PM
Turbo-LS's Avatar
Default Re: Push or pull Fan & shroud
pull always works better for several reason, numbe rone generally most fans move more cfm as a puller than as a pusher. the fan being on the front of the rad causes a restriction of the natural air flow when your driving.
shrouding the fan makes a HUGE difference when using a puller fan, allows the heat to be pulled out of the whole radiator instead of just where the fan is.
Just an FYI a 14" fan will fit on the half core rad and basically takes up the whole rad so a shroud is not needed. Thats what i run and works perfect even when boosting with the a/c system running in 100 degree heat
Old Apr 11, 2009 | 02:36 PM
thanks a lot man!
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
keebler65
Mar 18, 2002 02:35 PM
ithrowpoop
Mar 6, 2002 06:19 PM
