EG & DC Intercooler piping
Old Apr 13, 2009 | 11:49 AM
omgwtfbbq's Avatar
Default EG & DC Intercooler piping
Are they the same if the EG has a GSR in it? I have a lsv turbo 94 teg and want to transplant everything into a 93 EG. Anyone have any insight on whether the IC piping and the IC itself should all fit with no problem? Thanks in advance.
Old Apr 13, 2009 | 11:54 AM
kyden's Avatar
Default Re: EG & DC Intercooler piping
it should fit as long as the same intake manifold from the integra is used on the eg.
Old Apr 13, 2009 | 12:34 PM
omgwtfbbq's Avatar
the whole motor from the teg is going in, so the IM is the exact same. Just wanted to be sure.
Old Apr 13, 2009 | 12:43 PM
96 GSR-T's Avatar
Most of the EG's I have seen had the charge pipe coming through the same area where the ABS Motor is on Integra's, as long as the piping goes under the frame and over the tranny you should be ok.
Old Apr 13, 2009 | 12:49 PM
omgwtfbbq's Avatar
The integra wasn't fitted with ABS, so I think everything should bolt up fine. The IC on the teg is bolted under the front bumper brace, and the EG doesn't look like it has the same clearance behind the bumper, but if I have to cut into the brace, that'll be fine.
JHipps
May 8, 2014 07:10 PM
josh.p
Feb 26, 2009 09:48 PM
shoebox
Oct 4, 2005 10:42 AM
1bar
Jan 19, 2003 06:35 PM
