JRSC iTR!
Old Apr 9, 2009 | 09:42 AM
jdmsleeper12's Avatar
Default JRSC iTR!
i have a jrsc only boosting 1 pound... is it because i have a oem injectors? and im wondering will a s2k injector work with it?
Old Apr 9, 2009 | 10:49 AM
C_Rock77's Avatar
Default Re: JRSC iTR!
Injectors are not the issue...
Is your bypass stuck open? Is your belt slipping?
boostedcivicsir's Avatar
Mr. Badwrench
no its not because of your injectors. is the belt slipping?
Old Apr 9, 2009 | 02:00 PM
how do i know if my belt is slipping..? everything sounds fine....
Old Apr 10, 2009 | 09:03 AM
JDMCRX's Avatar
Ok first things first. When you punch it can you hear the supercharger
2. grab the belt and is it tight or loose the alternator and super charger belts
3. if they are most likey your bypass valve is stuck open. check it with ur hands see if it moves.
shahriar35
Dec 18, 2010 11:42 PM
nholmes
May 15, 2006 10:58 PM
JDMBOLONI
Nov 13, 2004 10:41 AM
