no spool on turbo
Old Apr 16, 2009 | 07:25 PM
jdmdikk's Avatar
Default no spool on turbo
i am posting this thread up for a friend..he has a 93 civic with a ls/vtec and a full turbo kit setup..for some reason there is no spooling comin out of the turbo,,the boost gauge goes only to 0 and thats it.we have checked all the pipping and couplers and they seem all fine.all the vacuum hoses are fine 2..what else can our problem be??
Old Apr 16, 2009 | 07:45 PM
FastEg6's Avatar
Default Re: no spool on turbo
What turbo is it? Could it be that the turbo crapped out and/or broke the shaft? Does the wastegate open? Give us some more detail on the setup, and the setup of the turbo and we'll go from there.
Old Apr 16, 2009 | 08:01 PM
B16Drag's Avatar
Do you hear the turbo spool at all?
I bet you have a freaken leak. Re-tighten ALL of the clamps. You may even consider using some of those 3M adhevises between the rubber hosings and the piping to ensure a tight seal.
Old Apr 17, 2009 | 05:56 AM
b20beast83's Avatar
what kind of wastegate
are there exhaust leaks
double check piping and couplers
Old Apr 17, 2009 | 06:15 AM
jdmdikk's Avatar
pipping and couples were all double and triple checked for leaks,the wastegate is tial and the turbo is turbonetics,,he said that he had the turbo on his other engine and the turbo worked fine but the motor blew..you can hear the turbo whining but no spool .there is absolutely no shaft play at all..the downpipe is not connected and is the only thing not connected..we even changed the vacuum lines on the wastegate 2 the 2 different positions and still nothing..
Old Apr 17, 2009 | 06:27 AM
b20beast83's Avatar
does he have the fire ring in the wg?
is exhaust coming out the dump
Old Apr 17, 2009 | 06:32 AM
jdmdikk's Avatar
i know that he does have the ring in the wastegate and the wastegate is staying closed he says.
Old Apr 17, 2009 | 08:45 AM
rick_rabies's Avatar
I'm not Rick!
can you spin the impeller with your finger?
Old Apr 17, 2009 | 08:52 AM
totsie7944's Avatar
Lol...he "says" the fire ring is installed? Why don't you open it up man and double check, also make sure its installed properly.
Try revving the car and feel with your hand if you can feel exhaust coming out of the dump tube.
And also as stated above, spin the wheels (fins) and make sure they turn together and that the shaft isn't broken. Does it spin freely when you spin it? If not, maybe the turbo is shot and its not being allowed to spin fast enough to make boost...
If its none of what I just said, you just have a leak somewhere and your missing it.
Edit: You didn't leave any rags in the turbo manifold did you? haha...not being a dick...people do that ****.
Old Apr 17, 2009 | 10:53 AM
bnorth's Avatar
Are you trying to get it spool by revving it or are you driving it with load on the engine?
Old Apr 17, 2009 | 10:04 PM
B16Drag's Avatar
Good point. It needs to have some load.
Old Apr 20, 2009 | 08:35 AM
jdmdikk's Avatar
we were driving the car ,,,,and we figuered out what it was...all the bolts for some stupid reason were loose on the turbo and i think he said that the seal inside wasnt on right..mind u that he had the turbo rebuilt str8 from turbonetics
Old Apr 20, 2009 | 08:45 AM
dpetro1's Avatar
they may have left them loose so you can clock it. also you need to put the downpipe on, you are gonna melt something or start a fire with no dp connected
si_motor_spt
31
Mar 19, 2010 09:47 AM
mattcalica
May 26, 2004 11:48 PM
Ty.
Feb 3, 2004 04:15 AM
OKSolSi
May 6, 2002 07:57 PM
