Integra Turbo Help
Old Apr 9, 2009 | 01:42 AM
millsd4's Avatar
Default Integra Turbo Help
Ive got a turbo for my 94 integra : Number is T0759, Garrett Turbo, off a talon. The internal wastegate is set for 10 psi or so, can i turn this down to 7 or so? im running stock internals on a high milage engine that burns no oil and pulls hard, is there a safe psi number that wont blow it up?
Old Apr 9, 2009 | 02:54 AM
almostboostedgsr's Avatar
Default Re: Integra Turbo Help
Id the internal wastegate is set at 10psi then your answer is no it can not go down. My last setup consisted of a garrett t3/to4e turbo with a tial external wastegate on a gsr motor. I was tuned with my hondata s300 with 10psi. I ran the car extremly hard for 5,000miles then pulled it out an sold it to a friend. The motor was perfectly fine when I pulled it out. I just got done assembling my new setup which is a fully built b16 head with a fully built gsr block with eagle ls rods, je pistons an a stock micropolished ls crankshaft. So pretty much I built an ls/vtec inside a gsr block.
Old Apr 10, 2009 | 01:23 PM
millsd4's Avatar
anyone elses help?
Old Apr 10, 2009 | 09:01 PM
TheShodan's Avatar
Moderator
10psi from a DSM stock turbo against a T3/T4 hybrid at 10psi is COMPLETELY DIFFERENT POWER and use. That T25 couldn't hold enough boost to power a baby stroller. too much work for very little benefit. And no, it won't even make 200whp with it. Sell it for 50 bucks to a DSM owner
Kelb
Sep 13, 2012 04:17 PM
Integra Type-GSR
Mar 6, 2008 09:15 AM
SkertySkerty
Jun 6, 2007 08:38 AM
AzN_Flava
May 5, 2006 01:19 PM
Smooth-GSR
May 3, 2004 03:11 PM
