MAP Sensor Wiring
Old Apr 12, 2009 | 11:40 AM
00si2's Avatar
Default MAP Sensor Wiring
I am wiring up a gm 3 bar map sensor. I cut the the plug off the old sensor clip and the wires aren't the same colors as the what is in the link below. I thought maybe i cut the wrong clip off but i don't see any other of the same clips with the correct color wires. I looked at the Hondata site and i have the same color wires as an rsx.
I have a:
Green and white
red and green
yellow and red
https://honda-tech.com/forums/forced-induction-16/some-information-about-gm-3bar-connnector-install-hondata-1440585/
GND (A) connects to Green/White on factory harness
MAP signal (B) connects to White on factory harness
5V (C) connects to Yellow/Red on factory harness
Old Apr 12, 2009 | 11:51 AM
Ls_dx's Avatar
Default Re: MAP Sensor Wiring
Ok, so whats the problem? The hondata site is what I always use.
Old Apr 12, 2009 | 11:55 AM
00si2's Avatar
I dont have a white wire on the harness
Old Apr 12, 2009 | 04:47 PM
b20beast83's Avatar
use DVm to test
Old Apr 12, 2009 | 04:52 PM
jdm602's Avatar
red goes to yellow/red. white goes to red/green. black goes to green/white.
joshd_bh
Apr 18, 2016 12:30 PM
russd210
May 22, 2011 11:35 AM
tacosandbeans
Sep 20, 2010 10:44 AM
whackassfawker
May 31, 2005 03:52 PM
HaveNoLife
Feb 28, 2005 05:22 PM
