Turbo sizing help?
Old Apr 10, 2009 | 01:20 PM
whitehatchguy's Avatar
Icon2 Turbo sizing help?
I have the motor built b20 block sleeved 9:1 wiseco pistons for b16 head arp rods acl race bearings b16 head p&p skunk2 valve train skunk2 manifold complete fuel system but i need help picking a turbo. I have no idea on what size turbo and a/r size i need.I wanna push around 20lbs and i am running q16 vp fuel.
Old Apr 10, 2009 | 01:50 PM
EJ8 944's Avatar
Default Re: Turbo sizing help?
Instead of picking a PSI amount you want to run, Decide how much HP you would like to make. From that answer, you can narrow it down to a few turbos.
Old Apr 10, 2009 | 03:29 PM
I just wanna get between a 10 and 11 second quarter. I am afraid to much horsepower would be over kill.
Old Apr 10, 2009 | 03:40 PM
JwithTHEek's Avatar
should have a done a gsr block.
Old Apr 10, 2009 | 06:25 PM
Hobkins's Avatar
B20 block is fine, it's even sleeved and built up, no need to worry about that. As EJ8 said you need to pick a power goal.
I know many different people with many different types of turbo's that run 10 and 11's. Give us a power goal.
Old Apr 10, 2009 | 06:32 PM
cslegacy's Avatar
gt35
Old Apr 10, 2009 | 08:42 PM
TheShodan's Avatar
Moderator
Pick a HP amount, please. No E.Ts. No PSI numbers. Get specific. Or else you'll get the simple responses like you have above. Get to work.
Old Apr 11, 2009 | 06:38 AM
dahmuno's Avatar
60-1 is great for high boost if you have a built motor, or try pushing a t4 lol
Old Apr 11, 2009 | 06:49 AM
TDautowerkes's Avatar
to make 500-525 whp on a stock cam b20/vtec a t3 .82 A/r billet 6262 should wprk good and get good ET's with the wide powerband you will have.....
Old Apr 12, 2009 | 05:55 PM
I think between 550 - 600 hp would get me in the E.T. I want if i get the weight down and run wrinkle walls.
Old Apr 12, 2009 | 06:12 PM
Schister66's Avatar
Man U FTW
I dont know how to really help you, but i will give you this...you dont need 550-600whp to run in the 10-11 sec range. SLS built a simple piston/rod B16 with a 57 trim on 110oct and ran in the 10.3xx's consistantly. I suggest doing more research before moving forward on anything...
Old Apr 13, 2009 | 06:12 PM
EJ8 944's Avatar
x2, I think you are getting ahead of yourself, you really need to have a plan before embarking on something like this.
akarooster
Aug 3, 2012 05:41 PM
dfinch88
Aug 5, 2010 12:46 PM
b20vdelsol619
Aug 29, 2009 02:39 PM
b20vdelsol619
Aug 29, 2009 01:22 PM
seldon
Aug 21, 2009 09:54 PM
