boost problems with jrsc
Old Apr 8, 2009 | 09:16 PM
budlightjunkie's Avatar
Default boost problems with jrsc
i have a jrsc on a lsv with gsr head, on a base map with 440s, was told 8 psi i just put boost gauge not 8
need to know whats wrong first is it normal for vacuum to be at 20 at idle?
then 1st and 2nd&3rd gear w.o.t almost 6psi and drops to 4 at high rpm?
but 4th and 5th at 7psi then drops to 4psi at the top end?
any help woul be greatfull
cat has normal boltons,i,h,e headers are really pinched on the bottom, not sure if that has something to do with it
Old Apr 8, 2009 | 10:50 PM
Hanmin's Avatar
Default Re: boost problems with jrsc
Maybe your filter is too restricting?
Where did you place your boost gauge vacuum line?
Old Apr 9, 2009 | 05:09 AM
filter isnt open on the back end not sure , ill buy new one
boost line is teed off the back of charger, also the one that goes to fuell pressure reg?
Old Apr 9, 2009 | 10:52 AM
Jaker's Avatar
Pinched header would lead to higher boost numbers, as the boost would back up in the intake manifold because it can't get through the motor. Are you belts tight, and not slipping? Usually when you loose boost at higher RPMs, it due to slipping belts.
Old Apr 9, 2009 | 11:07 AM
Dark_Teg's Avatar
X2-I have this problem with my Mustang. I had to go with wider pulleys with more ribs to fix the issue.
Old Apr 9, 2009 | 04:43 PM
nextproject97's Avatar
I had boost dropping off at high rpms also and tightened belts problem solved. Just remember the belt from crank to alt drives the alt which drives the blower so make sure you check both belts could be either belt causing boost loss
Old Apr 9, 2009 | 09:25 PM
thanks guys for the info.... ill try that tmmrw long work day today, anybody heard of pullyboys.com the sell smaller pulleys for the charger...thinking about going with 2.6 size pulley need that boost lol....
Old Apr 10, 2009 | 06:17 AM
I CRX I's Avatar
i hope you mean 3.6, if your haveing slipping problems now...wait till you put a 2.6 on it, not to mention you'll probably blow somthing.
Old Apr 10, 2009 | 10:44 AM
I got the car with the belt it has on it, 7pounds is not enough with 9.5.1 compresion
ZCcivic91
Sep 9, 2007 07:26 PM
boostedeghatch
Jun 29, 2005 12:40 AM
larryd
Oct 11, 2004 07:06 PM
sr20dettrex
Jan 13, 2004 07:02 PM
asnsensasian
Jul 3, 2003 09:59 PM
