HT Silicone Coating
Old Apr 14, 2009 | 04:42 PM
b20beast83's Avatar
Default HT Silicone Coating
Anyone use DEI HT Silicone Coating For their manifolds
I am thinking of using this can for heat protection.
Does it work without using the heat wrap?
http://www.designengineering.com/pro...sp?m=sp&pid=13
Old Apr 14, 2009 | 04:49 PM
spoolinfool's Avatar
Default Re: HT Silicone Coating
It will not be effective in reduing underhood temps without the wrap.The wrap itself is the insulator and the silicone spray helps the wrap repel moisture to keep you header from rusting.My opinion is it's not needed if you already have the wrap.
Old Apr 15, 2009 | 05:15 AM
b20beast83's Avatar
its for a log manifold
i wanna paint it.
its a kind of eyesore under the hood
Old Apr 15, 2009 | 05:20 AM
twkdCD595's Avatar
if you want a budget coating that you can do yourself and will hold up to that heat pretty decently (eventually it will come off but it takes a little while)... check out some VHT high temp 2000 degree paint.
KINGVEM^^ED6
Paint and Body
Aug 17, 2011 09:51 PM
toshko321
Sep 5, 2009 03:31 AM
lando griffin
Apr 13, 2009 09:16 AM
BDogggUT34
May 23, 2007 03:04 AM
leadtrum
Jun 20, 2003 04:17 PM
