B16A2 Safe Boost?
Old Apr 7, 2009 | 09:21 PM
blacc_ej1's Avatar
Default B16A2 Safe Boost?
how much PSI can i run safely on a stock B16A2?
Old Apr 7, 2009 | 09:27 PM
Hobkins's Avatar
Default Re: B16A2 Safe Boost?
Way to many people ask this...
Once again, there's no "safe psi" you can run. On a stock block I would not run more then 10 psi ( again there's no set number!) sure your buddy with a b16 swap was running 18 psi for 3 years I don't care. To keep your car in good working condition and decent hp I would grab a 8 - 10 psi spring and just keep it there. Other's will disagree but this is my person opinion.
Old Apr 7, 2009 | 09:33 PM
jdm602's Avatar
i ran 12 lbs on my b16a2 and made 351.
you can run almost any boost. timing is what the questions should be...which is directly related with the amount of boost you run.
Old Apr 7, 2009 | 09:41 PM
blacc_ej1's Avatar
timing? if i boost, how should i adjust timing?
Old Apr 7, 2009 | 09:46 PM
jdm602's Avatar
thats done through the tune. its when the ecu tells the spark plug to bark. whoever tunes it will do all the tuning with timing. you just gotta tell them how much boost or power you wanna run.
Old Apr 7, 2009 | 09:49 PM
blacc_ej1's Avatar
sweet thank you man! that clears a lot of stuff up. How much would a tune cost regularly?
Old Apr 7, 2009 | 09:52 PM
jdm602's Avatar
depends on what its tuned on. find a local tuner or performance shop and they can tell you or get you in the right direction.
Old Apr 8, 2009 | 03:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
seek ths faq's this question has been asked many times.
blackeg
Jun 20, 2011 12:14 PM
1990hondaHF
Oct 26, 2010 06:36 AM
ThinkRevolution
Aug 17, 2006 05:13 AM
Turbo-Si
Mar 6, 2004 10:14 PM
1.8T_EG
Oct 25, 2002 02:46 PM
