Help diagnose this piston failure.
Old Apr 14, 2009 | 06:32 PM
shawn69's Avatar
Default Help diagnose this piston failure.
So driving on the freeway, full boost 4th gear, looked down to see my temp needle 3/4 way up. I put it into neutral and cranked the heater, but the engine just died.
I wasn't sure if it was a piston or just a headgasket until today.
Look at the #2 piston,
AFR was between 10.9-11.8, timing is retarded .75 degrees/psi
This happened at 15psi
Was this due to the overheating engine, or just bound to happen with stock pistons?
Setup:
Stock gsr head
stock b18a block
arp headstuds
precision 780cc/min injectors
walbro 255
garrett t3 60-1 T04S housing .63/.70
etc...
Old Apr 14, 2009 | 06:35 PM
shawn69's Avatar
Default Re: Help diagnose this piston failure.
94 octane
about 9.7-9.9:1 compression
Old Apr 15, 2009 | 12:39 AM
david974's Avatar
what is your timing at 15 psi?
Old Apr 15, 2009 | 04:32 AM
m R g S r's Avatar
15 psi on a 60-1 on a stock motor? What were you making? around 350-375?
Old Apr 15, 2009 | 04:42 AM
b20beast83's Avatar
i was thinking the same thing
too much boost/power for stock internals
btw i didnt see the damage to the pistons
can anyone point it out
Old Apr 15, 2009 | 07:24 AM
sweetfwdthunder's Avatar
Look near the intake valve pocket and you'll see that it started to melt
Old Apr 15, 2009 | 07:39 AM
jdm inc's Avatar
wouldnt that be piston no. 2?
Old Apr 15, 2009 | 08:45 AM
eK24monster's Avatar
You pushed that motor harder then you should have.
Old Apr 15, 2009 | 09:36 AM
blaze the chemi's Avatar
Now that you have the motor open, order some good rods and pistons and slap them in. My ringlands blew on me and I threw in some crower rods and srp pistons.
And that is #2 cylinder that melted. I kept looking at 3 and I couldn't see anything.
Old Apr 15, 2009 | 09:46 AM
b20beast83's Avatar
me too
i was looking at number 3
lol
Old Apr 15, 2009 | 10:01 AM
gringotegra's Avatar
WRONG....
If it was a broken ringland thats one thing.. but he has a melted piston.. Something else is wrong...
Too much power on a stock engine did not cause that
How long were you in boost in 4th? were you ripping on it for a long time?
Old Apr 15, 2009 | 10:15 AM
EARLdaSQUIRREL's Avatar
official honda whore
looks like you had too much timing/ ran too rich or just plain and simply needs a proper tune
btw thats cyl #2 not #3
good thing ls blocks are cheap
Old Apr 15, 2009 | 10:18 AM
Originally Posted by EARLdaSQUIRREL
looks like you had too much timing/ ran too rich/ran tooo lean or just plain and simply needs a proper tune
X2... and added some
Old Apr 15, 2009 | 10:19 AM
boosted91crx's Avatar
i agree , that sucker is melted not broken , so that cyl might have a injector that isnt flowing as well as the other 3
Old Apr 15, 2009 | 10:50 AM
b20beast83's Avatar
how will running to rich cause this?
too much heat from running too rich?
Old Apr 15, 2009 | 11:15 AM
keving85's Avatar
detenation that caused a hot spot and melted that piston. i would look at your injector for that cylinder as stated previously.
i would say you were on the freeway for a while running it like that.... maybe 20-30 mins pretty hard without a rest?
a lean condition like that can run for years without problems but soon as you put a good amont of time on running it hard for a while with out resting you run into creating hotspots that will melt like taking a tourch to it.
kev
Old Apr 15, 2009 | 11:24 AM
shawn69's Avatar
kev
I went through 2-4 gears. i might have been just into 5th at the time, cant recall for sure. I was not on it for all that long, i was driving around for like 20 min prior, but not hard.
Timing is about 15 degrees. This is on turboEDIT.
The injectors are still brand new, pretty much. How much of a percent difference could there be between new precision 780cc/min injectors?
Old Apr 15, 2009 | 01:08 PM
sq_creations's Avatar
You exceeded the knock threshold of your fuel. It was detonating to cause that damage.
Old Apr 15, 2009 | 01:54 PM
shawn69's Avatar
This engine should operate at around 198 F right?
So if it increased from normal levels to around 220 F maybe even higher, how much does affect knock threshold and increase detonation?
I've seen lots of places that have wiseco and eagle combination deals, where is the best place(aka the cheapest)?
Old Apr 15, 2009 | 07:04 PM
Sr420Det's Avatar
I believe this is due to the tune. It needs a professional tune, I've created a few cleff lips (never on cast piston though) and alot of broken ringlands. Probably the gear compensation, Do you know what your doing with it? There's a lot more load at those speeds, Im sure you were probably eclipsing 130mph. Werent you.
What kind of plugs you running? Hows your exhaust, lots of back pressure? Probably way to much power too.
Old Apr 15, 2009 | 07:24 PM
shawn69's Avatar
I was doing 180km/h, which is 111 mp/h. What do you think was wrong with the tune? Why does it need a "professional tune"? I'm an engineering student, i'd rather do it my self and learn than pay someone else who probably knows as much as i do to do it. Plus i'm broke.
Brk7es, open downpipe.
What the hell is too much power? that statement doesn't make sense to me.
Old Apr 15, 2009 | 07:39 PM
Sr420Det's Avatar
Cast pistons can only handle so much but I figured you wouldve broken the ringland first. Guess it just got to hot, maybe due to a lean mixture through mechanical failure or whatever it may of been. A open downpipe will throw your af ratios off.
You remember doing 111mph but dont recall weather you were in 5th? Maybe you should ask your professor
Old Apr 15, 2009 | 08:28 PM
shawn69's Avatar
LS transmission, i would have guessed a ringland too. That would be from cylinder pressures too high right?
So it must have been detonating somehow, i'm wondering
Is 15 degrees too much?
Does turboedit change things in the background i'm not aware of?
An overheating engine causing the knock?
Oil vapor in the intake?
Old Apr 16, 2009 | 03:07 AM
non-VTEC's Avatar
if turboedit is anything like uberdata/crome then it may have some issues controling timing after a certain point.
plus the fact the stock cast pistons dont like the abuse for a very long period of time. also dont belive everything you see/read about how much power the stock pistons can take.
my suggestion is to invest in a good EMS... ectune, hondata, neptune ect....and just put a set of forged pistons in.
Old Apr 16, 2009 | 03:30 AM
Turbo-LS's Avatar
x2
And learn to drain the coolant before pulling the head, tisk tisk
