built ls
Old Apr 13, 2009 | 08:59 AM
ls_on_boost's Avatar
Default built ls
whats up i got a few questions i just bought a built B18B1 cp 9:1 pistons, eagle rods, acl race bearings, arp head studs, oil pump, water pump. i have also bought a ls head that has been ported and polished but everything else on it is stock now my questions is what head gasket should i buy for this motor im looking to get 400hp don't know if that matters.second what would the head be torque to how many lbs.thrid what brake pads and disc should be upgrade to with more horsepower you need more braking power but without braking your bank. i have a greddy turbo kit thats in my car now but this kit won't get me that hp so i will be buying another turbo kit like a ramhorn and nice size turbo don't know if this helps anyone who can help me with this let me know thanks.marcus
Old Apr 13, 2009 | 09:24 AM
Whatever's Avatar
Default Re: built ls
OEM head gasket.
80 lbs. with moly lube on head studs.
Old Apr 13, 2009 | 10:37 AM
can i get that gasket at discount or autozone?
Old Apr 13, 2009 | 10:49 AM
Turbo-LS's Avatar
FELPRO 35 bucks at local auto stores. same as stock. thats all i run in my engines and never once had a problem with them.
Old Apr 14, 2009 | 07:54 PM
ok thanks anyone know about brake upgrades i wanna keep the stock calipars but bigger rotors i seen in a magazine aem was selling biiger rotors and keeping the stock bracks but i can't find where i seen this ive been searching online and found nothing
Old Apr 15, 2009 | 05:33 AM
Turbo-LS's Avatar
AEM makes a kit, comes with larger rotors and brackets to move the calipers out. BUt im pretty sure you need to run 17" wheels to clear them.
Old Apr 15, 2009 | 05:36 AM
Schister66's Avatar
Man U FTW
If you're really concerned about braking, pick up a set of Brembo X-drilled rotors and some aggressive pads. That's what i did with my setup...i was having too much fade at the track so i upgraded. It was a good choice.
Old Apr 15, 2009 | 05:48 AM
would these pads be fine
http://www.autoanything.com/brakes/61A3071A0A0.aspx
Old Apr 15, 2009 | 05:52 AM
do you have a link i only see brembo sport slotted or sport drilled
Old Apr 15, 2009 | 06:44 AM
well i didn't buy a ram horn instead i bought a top mount does anyone know a good place to buy a turbo from for my setup not sure what size i need 400-500hp range but not 1000 bucks i have about 700 to spend on a new turbo ive been researching on sizes but have not made up my mind on what i should buy
Old Apr 15, 2009 | 09:09 AM
Turbo-LS's Avatar
PBR race pads with brembo cross driled and slotted rotors can be had on ebay for liek 225 bucks shipped. Then get your self a set of stainless steel teflon braided brake hoses to replace the factory rubber ones and you will have more than enough braking for the car. Big brake kits are definatly not needed for these small cars, the stock caliper with upgraded pads rotors and lines will be more than enough. I run this exact setup on my teg and it stop on a dime.
I believe i fyou have money burning a hole in your pocket you can get a set or spoon monoblock 4 piston calipers for about 2000 bucks but completely not worth it unless its a certified stripped caged track car or something
what ever you do, DO NOT get some no name brake rotors lol
here is a link
http://cgi.ebay.com/ebaymotors/94-01...mZ370185128358
and lines
http://store.summitracing.com/egnsea...alse&N=700+115
Old Apr 15, 2009 | 07:14 PM
i will buy that combo asap thanks
Old Apr 15, 2009 | 08:24 PM
Turbo-LS's Avatar
Gl
Old Apr 16, 2009 | 04:12 AM
ty what turbo is good for my setup top mount 1000cc injectors tial wastegate 3 inch dp
looking 400-500hp something good for street and track what do your time slips look like
Old Apr 16, 2009 | 08:17 AM
Turbo-LS's Avatar
60 trim t04e with a .63 or .82 hotside stage 3 wheel would get you to 500 maybe little more with race gas and 350-400 on pump gas
60-1 or 62-1 with a .63 hotside is also a great turbo, very streetable and a nice compressor map and good for 600range on race gas
then thers the sc60 sc61 gt35 mayn options
Old Apr 16, 2009 | 11:39 AM
Schister66's Avatar
Man U FTW
The best turbo for your goals would fall into the GT30r, BW S256 / S258 range. An SC61 or GT35R are too large for your plans. Any of the aforementioned turbos (30r/256/258) will make around 400whp on pump gas (maybe more) and easily crack 550whp on race gas. Look into them...check my sig, you can see which i chose
Old Apr 16, 2009 | 06:05 PM
great info ty for your help
great info ty to for your help
Old Apr 16, 2009 | 06:31 PM
TheShodan's Avatar
Moderator
But you can forget any of those larger, well matched turbos for under 700bucks. save a little more cash.
Old Apr 17, 2009 | 04:24 AM
http://www.hondamarketplace.com/show....php?t=2321264
these are some of the sizes you recommended
Old Apr 17, 2009 | 04:33 AM
TheShodan's Avatar
Moderator
Right. For 400whp on pump gas... He lists it right here
T3/t4 61mm compressor wheel stage V turbine wheel ( comparable to SC61 ) 810 shipped
T4 P-trim turbine wheel with 61mm compressor wheel ( comparable to T3 SC61 or T61) 825$ shipped
I DO NOT recommend the 1st one he listed, 61mm compressor w/ stage III wheel. That is terribly mismatched
Old Apr 20, 2009 | 01:30 PM
well the guy i bought the motor from never shipped me the arp bolts so i purchased some it cam in the mail today but i think i bought the wrong ones can anyone tell me if these are the right ones they look short
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old Apr 24, 2009 | 12:55 PM
top mount came in today mounted it to my ls head to see how it would look i like it lol
Old May 8, 2009 | 04:23 AM
Whatever's Avatar
Those are main studs, not head studs. You bought the wrong thing... You also could of saved a ton of money by getting a cast top mount like Turbo-LS has on his car.
All you turbo guru's, would a Holset HX35 or HY35 work for him since he doesn't want to drop a ton of money on a turbo?
Old May 9, 2009 | 05:44 AM
thanks i just got some head studs i sold the wrong ones the top mount i got for 650 with 3'' downpipe thats not bad brand new
Prelude900
May 10, 2015 02:47 PM
TealCivic115
Oct 2, 2011 09:03 AM
Tong.Y
Jun 5, 2011 09:17 PM
ls_on_boost
Apr 13, 2009 07:40 AM
zCivic
Jan 13, 2003 03:41 AM
