dual wastgates?
Old Apr 6, 2009 | 09:16 PM
racingcrx's Avatar
Default dual wastgates?
anybody running them? I just want to see the setups out there. post pics please!!!
Old Apr 6, 2009 | 09:38 PM
blinx9900's Avatar
Default Re: dual wastgates?
This is not appearance/cosmetic section, nobody is just going to post pics. Do you have a technical question or goal?
Old Apr 6, 2009 | 11:51 PM
SD_Lurker's Avatar
HT White Ops
Originally Posted by Rubicashrama
As many of you are aware, the 944 Turbo has a single port wastegate with electronic boost control. Many of you are also aware that the Wastegate on the 944 Turbo gets weak with time and there are rebuild options that can cost about GBP 700.00. However, even a new or rebuilt factory KKK wastegate for the 944 Turbo has a major weakness - it is overcome by exhaust pressure at high RPM. This means that it is very difficult to achieve more than 0.7 bar of boost at high RPM. With the standard wastegate, there is no problem reaching an increased (and brief) over boost condition at 3,000 to 4,000 rpm - but to achieve considerably more power is not possible (safely) using a factory wastegate. Power requires RPM. If your car is not making boost at high RPM - it's not reaching its true power potential.
Most of you will have noticed how your Boost Gauge falls back as the revs rise - the factory gauge reacts very slowly, but with an accurate boost gauge you would be surprised as to how much the boost tails off. In the majority of cases, beyond 4,500 rpm - the boost tails off on the 944 Turbo using the factory wastegate (both 220bhp and 250bhp models). Recently a test was performed on a standard 250 bhp 944 Turbo with new factory wastegate (these retail at GBP 1,350.00!). A maximum boost of 0.82 bar was achieved and the boost rolled off to 0.7 bar and decreased further beyond 6,000 rpm. This car made an indicated 242 bhp. This was with a new Porsche supplied factory wastegate.
Wow, random.
Old Apr 7, 2009 | 01:50 AM
blinx9900's Avatar
Originally Posted by SD_Lurker
Wow, random.
Not random, is serious business! Is this not a Porsche forum? GTFO you damn Honda lover
Old Apr 7, 2009 | 02:02 AM
riceball777's Avatar
well i run a twin scrool manifold with a twin scrool t4 1.06 ar gt3582r on my evo.
its not my honda but hey you asked for 2 wastegates
Old Apr 7, 2009 | 04:34 AM
blinx9900's Avatar
riceball777 Who tunes your car and with what software? Can you not get more than 370whp with 91?
Old Apr 7, 2009 | 05:58 AM
Joseph Davis's Avatar
The 951 cup car in my front lawn disagrees.
Old Apr 7, 2009 | 07:10 AM
racingcrx's Avatar
sorry my question was sort of vague. I was wanting to get the lovefab turbo manifold for my h23 vtec and was looking at the one that has the dual wastegate setup. I'm aiming for 400-600whp with a methanol injection kit. I'm doing more research so I will know what i need to get.
here is the manifold http://lovefab.com/html/h_excaliber.html
Old Apr 7, 2009 | 07:55 AM
90blackcrx's Avatar
http://viewmorepics.myspace.com/inde...lbumId=2587220
Old Apr 7, 2009 | 12:50 PM
blinx9900's Avatar
Bro thats a froward facing manifold and per the literature on the site i believe it must be run with a water/air intercooler as a front mount will no longer fit, this all seems very excessive and expensive for just 400-600whp. Now if you were shooting for say 750-850 That manifold might start to be acceptable.
A regular non-divided manifold with a GT35r is all you need for your power goal, the manifold will be cheaper, you will only need one WG instead of two and you can run a normal front mount IC. I know thats not what you asked but this is just my opinion.
Old Apr 8, 2009 | 06:42 PM
racingcrx's Avatar
so what kind of manifold do you suggest? i guess i haven't looked hard enough or search. i'm guessing a cast manifold would work
Old Apr 8, 2009 | 07:19 PM
jdm inc's Avatar
here is the manifold i'm running from Straight line specialties.
Old Apr 9, 2009 | 04:01 AM
blinx9900's Avatar
Cast could work if you mod it to fit a larger WG but your on the right path with the tubular stuff, you just picked something way too hardcore.
Old Apr 9, 2009 | 04:13 AM
kyden's Avatar
cast manifolds don't do so well on h22's.
Old Apr 9, 2009 | 04:29 AM
legomytego's Avatar
its a evo they are not very effcient at making power but they can sure take alot of it my good friend has a 3076 on his and is not over 500whp ever notice it takes them 30+psi to max a turbo out and we max it out on our cars well before that we got the motor they got the drivetrain.
Old Apr 9, 2009 | 04:51 AM
blinx9900's Avatar
I always noticed that. I had a friend with a 3076r on his evo, with 22psi and an aggressive tune he made 340whp with 91 octane while my b16a/b makes 340whp with 12psi using the same turbo!!
Not to mention a freaking eg/ek/dc/em1 all have higher side impact crash ratings than an evo!
http://www.mitsubishisucks.com/cars/...de-impact.html
2 freakin stars!
Old Apr 11, 2009 | 09:20 AM
If You Slip You Die's Avatar
Old Apr 11, 2009 | 02:24 PM
scrooge's Avatar
Im kind of a noob when it comes to turbos but what benfit is it to have two wastegates instead of one? yeah i know sorry noob question!
Old Apr 11, 2009 | 04:16 PM
quicksilver1689's Avatar
i ♥ snails
its a divided setup
Old Apr 11, 2009 | 06:42 PM
blinx9900's Avatar
Its used on divided housing turbo setups, divided housing turbo setups generally spool faster so the point is not to run 2 WG the point is to have a divided housing turbo/manifold combo in order to increase spool up and running to WG is required for that setup.
Originally Posted by If You Slip You Die
What are you trying to say here?
Old Apr 26, 2009 | 10:00 PM
thtas my dyno chart on my twin scroll gt35r evo
370whp was on my old gt30r setup
Old Oct 1, 2009 | 01:39 AM
jackbilbow's Avatar
New User
Hi....Friends. I am a student of Automobile engineering. Your information helped me lot in collecting information for that. Pictures are very nice and helpful. Thanks for sharing with us.
Old Oct 1, 2009 | 07:13 AM
TiAL's Avatar
stupid scammers are getting creative, instead of whoring stuff out in posts, they make a 'somewhat' car related post with links in their sig LOL
grand champ
Jan 14, 2010 02:51 PM
bsmith100
Nov 30, 2008 08:27 PM
93hatched_projekt
Nov 23, 2005 12:31 AM
beepy
Sep 13, 2004 10:12 PM
TurBoXBirD16
May 10, 2003 11:47 AM
