Odd misfire issue. LS/b18b
Old Apr 12, 2009 | 12:21 PM
m R g S r's Avatar
Default Odd misfire issue. LS/b18b
So my head started to lift under boost right after we tuned it. So I went ahead and replaced the HG and threw in some ARP studs. Setup is stock LS motor (b18b)
After the HG/HS install, I started it and it sounded like a WRX. I could tell one cylinder was missing. Checked them all by pulling the plug wires with it running and it was cylinder 1 (closest to the Timing belt)
I thought it was the plug. Bought a new set of bkr7e's and gapped them down. Still missing at idle up to 3k rpm's, but runs awesome 3k and above, no breaking up even in boost. (smokes the tires in third :D)
So I figured it was the timing. Checked it with a timing light, and it is spot on.
*****Buttt....on cylinder 1 and cylinder 1 only, the flashes from the timing light are not consistent. It will flash consistently, then stop for a second then start flashing again. Check every other cylinder with the light and the flashes are evenly spaced and don't ever stop (the way it should be)
Okay so I replace the plug wire on cylinder #1. Still does it.
Okay I will buy a brand new set, possible two bad wires. Still does it.
Replaced the cap and rotor. Still does it. Checked it with another plug wire on cylinder number 1, still does it.
Maybe its the mechanical timing? Nopeee-- I just re-timed the motor and used the cam fixtures, so no way that only one cam is off by a tooth. And if the mechanical timing was off, it would show up with the timing light. (the 16deg BTDC mark wouldn't line up with the pointer on the T-belt cover.
The onlyyyyyy thing that is bugging me is not having the plastic cover on the distributor, the one that goes underneath the rotor and covers the coil. But I'm stumped because if it is somehow arc'ing out inside the distributor, it would do it all the time, and possibly on more than one cylinder. The car ran fine with the motor the way it stands before the HG install.
Also, like I mentioned, the motor runs perfectly in boost and upper RPM's, and it's not like it's really running on three cylinders where you have no power. Even down low, you can just hear it slightly missing, but the power is still all there.
Help me out I'm going crazy.
Old Apr 13, 2009 | 04:30 AM
m R g S r's Avatar
Default Re: Odd misfire issue. LS/b18b
nothin?
Old Apr 13, 2009 | 07:07 AM
19slocivic97's Avatar
my buddy had a similar problem on his h22 turbo, when we went to set the timing the light was acting strange, his car also was breaking up in lower rpm range. He checked everything and finally fixied it with a new coil. I think the timing light is acting up because your coil is weak at certian points of load and the secondary field collapse is to weak to light the inductive pickup of the timing light. hope this helps
Old Apr 13, 2009 | 07:13 AM
non-VTEC's Avatar
check compression. possible bent valve?
Old Apr 13, 2009 | 07:14 AM
Davidls's Avatar
mine did this too it was the ignition coil
Old Apr 13, 2009 | 08:45 AM
GsrIntegra789's Avatar
i have the same problem but mine only happens in the upper rpm range. Its buggin the crap out of me I cant figure it out, ill try putting using my msd coil.
Old Apr 13, 2009 | 02:04 PM
LShatchie's Avatar
definately sounds like the coil, easiest thing to try is swap ur dizzy with a known working one from a buddy, takes 30 seconds and can save alot of headache
Old Apr 13, 2009 | 02:18 PM
Peeonu25's Avatar
dizzy, plug wire, get a leak down test done to find out if you have a bad valve (doubtful)
Old Apr 13, 2009 | 03:54 PM
m R g S r's Avatar
sorry forgot to mention a comp test was preformed before and twice after HG install. It didn't change, exactly the same in every cylinder. I will try a new coil or see if my friend has a dizzy. If I swap dizzys and don't jump the ecu cel connector, will that alter the base timing and mess up my tune?
Old Apr 14, 2009 | 06:15 AM
your tune should be fine, just mark where the dizzy housing lines up to the head and put the new one to the same location
Old Apr 14, 2009 | 01:15 PM
m R g S r's Avatar
I swapped coils, still does it. I guess the ignitor? or like i said earlier, i'll see if i can find someone with a working distributor before i go out and buy one.
kbouchard1092
Sep 6, 2012 03:29 PM
m R g S r
Apr 13, 2009 10:06 AM
SpOoLiNg CiViC
Dec 23, 2006 11:39 AM
.teggyroo
Sep 10, 2006 03:28 PM
EGHatchy
Jul 24, 2002 10:33 AM
