quick fuel pump question
Old Apr 16, 2009 | 10:23 AM
cleanazcoupe's Avatar
Default quick fuel pump question
hey guys im currently running a b18 ls/vtec at 5 ps1 of boost with 450cc injectors tuned, but im running the stock fuel pump, is this bad? if i change it will it help at all?
Old Apr 16, 2009 | 11:37 AM
E85B18's Avatar
Default Re: quick fuel pump question
Your tuner should have told you if your set up is getting lean. Chances are youre fine at 5 psi. The only reason you would want a new pump is if you want to run more boost. With your set up i'd get a walbro 255 and run 10psi, why only 5?
Old Apr 19, 2009 | 07:01 AM
Topdawgg's Avatar
the REAL question, is 5psi on what turbo?
5psi on a T28 is going to be JUST alittle different then a GT4288R...
why dont people understand this?
Its less then 100$ for a walbro, get one.
Old Apr 19, 2009 | 09:12 AM
sweetfwdthunder's Avatar
I agree, they're cheap insurance..do it right the first time. If you can't afford to buy a walbro then you shouldn't turbo your car.
Old Apr 19, 2009 | 10:00 AM
Hobkins's Avatar
Yea I agree with you, but how many people do you know that runs a 42r at 5 psi... If your going to that extreme of a turbo you are not trying to make it streetable.
You can pretty much assume that he will be dealing with a relatively small turbo.
b16-t
Sep 2, 2009 05:59 AM
turboorsupercharger
Aug 18, 2008 07:02 PM
pro547
Jul 7, 2005 07:48 PM
Todapwr
May 12, 2004 07:52 PM
Familycarfromhell
Jan 19, 2003 09:18 AM
