Water Temp gauge??
Old Apr 17, 2009 | 07:47 AM
SurferDude905's Avatar
Default Water Temp gauge??
I'm in the process of installing my autometer water temp and I was curious... If I take out the stock sending unit and replace it with my sending unit will this affect the computer reading?
Old Apr 17, 2009 | 08:43 AM
totsie7944's Avatar
Default Re: Water Temp gauge??
I'd just take off the upper neck or lower water pipe and have it tapped and threaded...keep both and its super easy to do. A shop should charge you like $20-50, even tho it doesn't take that long at all...You can take them the part. They drill and tap, 10 mins later they hand it back to you haha
Old Apr 17, 2009 | 08:56 AM
boostedcivicsir's Avatar
Mr. Badwrench
leave the 2 wire sensor alone thats the ECT the ecu needs. the single wire sensor is the gauge sender. you can put it there only the stock gauge wont work any more.
Old Apr 17, 2009 | 09:00 AM
totsie7944's Avatar
That's why I recommend just tapping for a gauge temp sensor. I like having the stock one running as a backup just in case haha
Old Apr 17, 2009 | 10:07 AM
Si GUY99's Avatar
just another option http://www.nipponpower.com/~nippon/product.phtml?p=467
Zac W.
Apr 8, 2013 05:06 PM
BlackShingo
May 20, 2010 07:36 AM
Dilly
Jan 18, 2006 10:05 PM
turbotime
11
Sep 30, 2005 05:03 PM
VTECR021
Apr 22, 2004 08:04 PM
