Fmax's downpipe
Old Jul 14, 2002 | 07:39 AM
B16 BROTHER's Avatar
Default Fmax's downpipe
I am about a month away from purchasing a FMAX turbo kit. And I had wondered should I just have the shop install the kit and keep the closed loop wastegate dump or should I have them fabricate another downpipe which is a little bigger and run a atmosphere dump on the wastegate. Any help will be appreaciated and if anybody has pics of there engine bay with FMAX please post.
Old Jul 14, 2002 | 08:42 AM
kidkutz's Avatar
Default Re: Fmax's downpipe (B16 BROTHER)
have them modify it for an open atmosphere dump
Old Jul 14, 2002 | 01:42 PM
Etylorcen's Avatar
Default Re: Fmax's downpipe (kidkutz)
You're not going to run those lucas injectors and the mf2 unit are you?
Old Jul 14, 2002 | 02:07 PM
MiraiZ's Avatar
Default Re: Fmax's downpipe (Etylorcen)
Advice...ditch the MF2 and save yourself a couple hundred bucks... Have them specially fabricate a dp for you...the one that comes with the kit sucks!...I'd personally go closed looped, but thats your choice..
Old Jul 14, 2002 | 02:48 PM
JM Performance's Avatar
Default Re: Fmax's downpipe (MiraiZ)
everyone's saying the mf2 sucks....i've been using if for 8 months now and about 7,000 miles and its been fine. I'm finally going to dyno tune it w/ wideband tomorrow.....I'll post results.
Old Jul 14, 2002 | 02:51 PM
Default Re: Fmax's downpipe (00SilverLS)
and yeah, the dp design is a little weak....I had mine made 3" after it bends and I had them reroute the wastegate to the end of the dp. Its much better like this....but I still wouldn't go open wastegate.....too loud.
Old Jul 14, 2002 | 03:52 PM
I currently am running a JSRC and have decided to go turbo, so I am going to have this shop where I live do the install for me. I know what I am about to say is crazy but bear with me. I have seen it with my own two eyes. They use an FMAX kit, headgasket, and VAFC, and two days to have your car. The owner of the shop currently has about 13 cars running this set up with the mf2 and not one has failed yet. The owner gaurentees you 12,s or a thousand dollars back! on a stock block. And I know it sounds crazy but I have seen it with my own eyes even on singles. All of these cars are daily driven 12lbs set ups, please tell me what you think any comments will be greatly appreaciated.
Old Jul 14, 2002 | 05:48 PM
DeeJay's Avatar
New User
I had Scott at f-max make my DP open loop, they can make it either way. I highly recommend open loop because of the way f-max fabs closed loop, If it isn't a problem with smog checks in your area.
Old Jul 14, 2002 | 06:30 PM
GruvyTune's Avatar
New User
Default Re: Fmax's downpipe (DeeJay)
yea, i'm thinking of having mine redone open loop as well. It really isn't all that loud if you've been driving around with a 3" thermal exhaust you'll never notice the difference~!
[Modified by GruvyTune, 10:31 PM 7/14/2002]
Old Jul 14, 2002 | 06:39 PM
well I am not really concerned about noise because I don't drive the car everyday. currently have injen intake, dc 4-1, test pipe, greddy evo, o2 simulator, act extreme, and clutchmasters flywheel. My exhaust is heidously loud because of the testpipe so I am use to the noise, am looking at it for more of the performance aspect of things.
Old Jul 14, 2002 | 06:42 PM
justagsr's Avatar
where are you getting it installed in SA? I haven't really heard of any good shops in town since I have left and even when I was there. I may have to check it out just for grins when I get back in town.
Old Jul 14, 2002 | 06:55 PM
It is a very clean and reputable shop in San Antonio called Precision R. The number is 210-829-8200 ask for William he is the owner.
Old Jul 14, 2002 | 07:19 PM
MiraiZ's Avatar
open loop is way loud!....and I doubt that it legal ...anywhere!
Old Jul 22, 2002 | 03:17 PM
12SecHatch's Avatar
hey bro, im from precision r with my 92 hatch
u may of seen my del sol with the sohc vtec with a fmax
now i have the setop in my 92 hatch
good choice on the shop and turbo
there the only shop in sa i go to
Old Sep 17, 2002 | 06:18 AM
SoulSurfer's Avatar
William is a very helpful guy. I live in Korea and still buy my parts from him and will probably get my FMAX kit off of him as well. I'm going to try and install it myself though. God help my engine please!
[Modified by LSDelSol, 12:19 AM 9/18/2002]
Old Sep 17, 2002 | 08:46 AM
fastludeh22's Avatar
Default Re: Fmax's downpipe (LSDelSol)
about the atmosicphiric discharge thing, according to the site nothing needs to be fabed, it is a simple process...at least on the lude kits..
Old Sep 17, 2002 | 08:48 AM
Default Re: Fmax's downpipe (93ludevtec)
from the site:
"ATMOSPHERIC VS. CLOSED-LOOP: An intersting finding that we have recently found is that we gained an additional 44 HP at 9 psi of boost by simply discharging the wastegate into the atmosphere instead of discharging it back into the downpipe. All other dyno sheets on this site that compare with DRAG are derived with the wastegate discharged into the downpipe and will be tested for possible gains with atmospheric discharge. Atmospheric discharge is not a set-up that would be allowed within the constraints of CARB testing, so closed-loop will be standard in the kit. For those of you who race off-road, know that to make the change from atmospheric to closed-loop is a simple bolt-on/off of existing parts and requires no major modification to produce the additional horsepower. In other words, no more money need be spent just to make more power. We are in the process of testing an alternative wastegating method that will be incorporated into the kit to make a racing only set-up easily convertible for track-only use."
http://www.f-max.com/PreludeSys.htm
[Modified by 93ludevtec, 5:49 PM 9/17/2002]
95stangkillah
Aug 20, 2003 10:42 AM
rrei
Jul 18, 2002 08:06 AM
The Punisher
Nov 1, 2001 08:24 PM
TurboTypeR98
Oct 12, 2001 05:50 PM
CrAZyRaCeR
Jul 21, 2001 09:54 AM
