Boosted sohc Times
Old Jul 14, 2002 | 09:44 PM
Drew Peacock's Avatar
Default Boosted sohc Times
Hello I am just trying to find out what my car is likely to do in the 1/4 mile, car two door teg weighs 2522lbs including driver @8psi I get 170whp and at 10psi 196whp, no lsd but have koni yellows and low springs on street tyres toyo T1s any ideas . Thanks
Old Jul 14, 2002 | 09:46 PM
bretx0r's Avatar
Default Re: Boosted sohc Times (turbozxi)
im guessing mid-high 14's with excellent driving
Old Jul 14, 2002 | 09:56 PM
Default Re: Boosted sohc Times (bretx0r)
For the low boost setting do you mean? I am hoping for high 13s with 196whp.
Old Jul 14, 2002 | 09:57 PM
Smashback's Avatar
I don't think you're going to get it without at least slicks.
Old Jul 15, 2002 | 12:10 AM
Default Re: Boosted sohc Times (mplex2000)
Any of you guys actually run the 1/4 with a similar setup I've seen a few guys do 13s with less power same sort of weight 2500lbs no slicks.
Old Jul 15, 2002 | 01:19 AM
SilverS's Avatar
whats your fuel set up??
Old Jul 15, 2002 | 04:52 AM
DSF's Avatar
DSF
https://honda-tech.com/zerothread?id=230175
Old Jul 15, 2002 | 11:20 AM
Default Re: Boosted sohc Times (DSF)
Thanks so I guess your saying yes 13s but your going to need drag radials.
Old Jul 15, 2002 | 11:46 AM
ludelvr's Avatar
We took my friend's turboed civic ex (si in Canada) and he ran a 15.3 on a hot and humid day. Elevation was estimated at 6300 ft and time corrected, it wouldv'e been low 14's or so. I'm pretty impressed because before, his car woulds ran a 17 or so, and other cars of the same setup have usually ran a high 16 - low 17. Oh yah, his set up is a basic drag kit at 7psi on street tires.
[Modified by ludelvr, 8:46 PM 7/15/2002]
Old Jul 15, 2002 | 01:25 PM
SilverS's Avatar
still wondering what your fuel set up is???
Old Jul 15, 2002 | 04:36 PM
JJ-Built's Avatar
Default Re: Boosted sohc Times (2000EX)
370cc, 8:1 fmu vortec, field afc, 255 lph intank pump.
oh and 1.1 bar f- max kit 12.5 112mph
Old Jul 15, 2002 | 09:59 PM
Default Re: Boosted sohc Times (jjgotboost)
Nice times cars gutted I suppose?any dyno numbers!
ah my fuel setup is a piggyback style chip running 3 extra injectors with ignition timing retarded on boost, hi flow fuel pump race gas at the high boost level.
Old Jul 16, 2002 | 09:22 AM
8psisi's Avatar
i ran a 14.64 with my jrsc@6psi on my 89crxsi street tires and removed headlight.short style intake and some bull **** header and exhaust
Old Jul 16, 2002 | 11:45 AM
flip1199's Avatar
Default Re: Boosted sohc Times (8psisi)
15.4@86
93 4dr civic sohc non-vtec with full interior and a nice heavy bodykit. oh did i mention after about the 1/8 mile mark the car stated bogging
My only mods were:
t3/t4 turbo @ 10 psi untuned
holley intank fuel pump
fmu
stock block
stock injectors
Too bad on my next run i overshot the boost to 14 lbs and the damn car cut off
Old Jul 17, 2002 | 01:34 AM
Default Re: Boosted sohc Times (flip1199)
https://honda-tech.com/zerothread?id=178590 To the folks how said you can't run 13s without slicks .
Old Jul 17, 2002 | 07:03 AM
auto-x's Avatar
New User
teg with sohc engine? are u in japan?
Old Jul 17, 2002 | 11:24 AM
Default Re: Boosted sohc Times (gud boi)
New Zealand we get all kinds of JDM cars, the curb weight of a car is what just the car no passengers and half a tank of gas?
Old Jul 17, 2002 | 12:17 PM
5thgenkitty's Avatar
13's are possible but you will need drag radials for sure....
Old Jul 17, 2002 | 05:22 PM
Default Re: Boosted sohc Times (5thgenkitty)
Didn't you check the link? dude's running 13s street tyres full interior ex coupe Curb weight is 2390 + driver with 8psi. So it can be done he's probably a very good driver though.
nerdsports
Dec 11, 2006 12:44 AM
SOHCboost
May 28, 2005 12:39 PM
pip9
Nov 17, 2004 02:17 PM
91integraLSVTEC
Jan 15, 2004 04:54 PM
b20turbojason
Nov 10, 2003 09:53 PM
