FMU Disks? which is which
Old Jul 12, 2002 | 09:48 PM
Tuan's Avatar
Default FMU Disks? which is which
How do i know which disk to use? Which one is 12:1, 10:1, 6:1 and etc? which combination? PLEASE HELP!!! What i really want to know is which one is the 12:1 disk! Thanks guys
[Modified by B20Zturbo, 12:43 AM 7/15/2002]
Old Jul 13, 2002 | 03:52 AM
rjardy's Avatar
Default Re: FMU Disks? which is which (B20Zturbo)
your picture doesnt work.
Rob
Old Jul 13, 2002 | 05:33 AM
niedejb's Avatar
Default Re: FMU Disks? which is which (rjardy)
The 12 is the biggest.
Old Jul 13, 2002 | 07:54 AM
greengangsta's Avatar
It depends on what size injectors you will be running. If you are using stock injectors go with the 12:1 fmu. The bigger your injectors you use, the smaller fmu you need to use. ex. 310cc with 8:1 or 10:1
Old Jul 13, 2002 | 11:27 AM
Tuan's Avatar
Default Re: FMU Disks? which is which (greengangsta)
I'm asking which disk is which? if you look at the picture, if you can't see it please look at the link below and then click at the bottom most picture.!!! Thanks guys
Old Jul 13, 2002 | 04:20 PM
niedejb's Avatar
Default Re: FMU Disks? which is which (niedejb)
Guess I have to say it twice.
Old Jul 13, 2002 | 05:21 PM
rjardy's Avatar
The one on the right.
Old Jul 14, 2002 | 12:45 AM
Tuan's Avatar
oops, thanks man! Do i just install the biggest disk? What about the rings? So in order to use the 12:1 i just put in the largest rings and disk together? that's all i need to know!
[Modified by B20Zturbo, 8:52 PM 7/14/2002]
Old Jul 14, 2002 | 11:52 AM
Tuan's Avatar
Thanks guys
[Modified by B20Zturbo, 12:44 AM 7/15/2002]
TurdBlown Teg
Jun 17, 2006 10:37 PM
turbo89civicb18hatch
Apr 5, 2004 10:41 AM
BoostedB20A
Dec 15, 2002 02:51 PM
freeplay
Dec 1, 2002 09:41 AM
00 Si
Jun 28, 2001 08:55 PM
