waste gate presure source?
Old Jul 14, 2002 | 12:16 PM
Cramerox's Avatar
Default waste gate presure source?
can i tap a hole into the pipe after the IC and before the TB for my waste gate vacume source?
because i dont want to run a line all the way from the mani to the waste gate.
seems more accurate because the waste gate will compensate for the presure drop? after the IC
Old Jul 14, 2002 | 12:58 PM
TriK's Avatar
Default Re: waste gate presure source? (Cramerox)
i want to know that to
Old Jul 14, 2002 | 01:14 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
that's where my source is. i haven't tried it off the manifold.
Old Jul 14, 2002 | 01:23 PM
HXMan's Avatar
I have it going to my manifold.
Old Jul 14, 2002 | 01:26 PM
Dee's Avatar
Dee
Default Re: waste gate presure source? (TriK)
I use a AVC-R so a -6 line attaches to the bottom of the w/g while a -4 tapped near the -6 attaches to the boost solenoid and the top of the w/g. Both lines are tapped less than 12" from the compressor housing and before the IC. Initially I was using all -4 lines and when I changed the bottom line from a -4 to a -6 boost came online a lot faster in first and second gear.
Old Jul 14, 2002 | 04:16 PM
Cramerox's Avatar
Default Re: waste gate presure source? (Dee)
Well the reason why i wanted to get my source from the intake arm...because it seems easier and cleaner having a vacume line go straight from wg to the arm. I didnt want to run the line all the way back and zip ties everywhere.
Dee-what is the bennifit of using ss braided lines for the vacume lines? I guess protection...is it really nessesary?
Old Jul 14, 2002 | 05:44 PM
Flamenco-T's Avatar
I did this with mine...I am running all the vaccum lines to the back of the IM,
no more visible Tees..
Old Jul 14, 2002 | 06:29 PM
Dee's Avatar
Dee
Default Re: waste gate presure source? (Flamenco-NA)
I used SS lines because I had a crapload of it!
Old Jul 14, 2002 | 10:19 PM
Cramerox's Avatar
you guys are great....
Flaminco and Dee you guys always come through.
Marc
Edit: BTW what is that around the nipple stan? is that just jb weld stuff?
[Modified by Cramerox, 11:20 PM 7/14/2002]
Old Jul 14, 2002 | 10:56 PM
Flamenco-T's Avatar
Marc
teflon tape...no leak
Old Jul 15, 2002 | 07:45 AM
SiRkid's Avatar
holy bigger lines batman
Old Jul 16, 2002 | 10:22 AM
PROFILES2000's Avatar
lol i thought u posted a pic of my manifold. looks good!
d15bfi
May 5, 2012 03:42 AM
Unseen Racer
Jan 14, 2009 06:03 PM
99delsol
Sep 20, 2006 06:57 PM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
ClubSiRacer
Nov 12, 2003 05:10 AM
