My fuel setup, you comments are welcome and appreciated. (LONG)
Many thanks to Dusin and Art, they helped a ton with this.
Will it work???
<u>FUEL SYSTEM </U>
(1) 12mm x 1.25 -6AN 90 degree hose end, part # EAR-849091
(Connects directly to top of stock fuel pump bracket)
(X) -6AN Stainless Steel Hose
(1) -6AN Straight Swivel-Seal hose end, part # EAR-800106
(Connects to inlet of Aeromotive Fuel Filter)
(1) -10AN to -6 AN reducer, part # 991914
(Allows use of -6 line to and from the Aeromotive fuel filter since it has -10AN ports)
(1) Aeromotive Fuel Filter, part # AEI-12304
(Connects to outlet of Aeromotive Fuel Filter)
(1) -6AN 90 degree tube Swivel-Seal hose end, part # EAR-809106
(Connects to inlet side of AEM fuel rail)
(1) -6AN Union, part # EAR-981506
(Used to connect swivel seal fittings)
(1) AEM Fuel Rail
(Connects to outlet side of AEM fuel rail)
(1) -6 45 degree tube Swivel-Seal hose end, part # EAR-804606
(Connects to side inlet on Aeromotive FPR)
(1) Aeromotive FPR, part # AEI-13109
(1) -6AN Econ-o-fit blue, part # EAR-900206
(Connects SS line to stock return line)
Did I forget anything? How much SS hose should I order?
Will it work???
<u>FUEL SYSTEM </U>
(1) AEM Fuel Rail
Re: My fuel setup, you comments are welcome and appreciated. (2K_TEG)
And dustin...what is with the stat o seal for the stock fuel filter bulkhead? I didn't see any pictures, what needs to be done there?
9/16" Stat-o-seal, part # EAR-178009
(Seals bulkhead fitting on stock fuel filter bracket)
I've also added these to the shopping list:
-6AN port plug O-ring seal, part # EAR-581406
(Blocks off extra Aeromotive FPR inlet)
-10AN Buna O-rings, part # EAR-176010
(Seals reducers on the fuel filter)
Dutin ordered 25 feet of the ss line to run to and from the tank. If you want to really save money use 3/8 aluminum or steel pipe instead of the ss hose. It'll be stronger, last longer, and CHEAPER. For 25' of pipe its only $15, where as hose will be over $100. But you need a 3/8" tube beader to flare the end so you can mate the hose ends to it. I did this with my water cooled bearing housing, but if I ever have the time I will do that to the fuel lines also.
art
art
New User
Arturbo, when you speak of the pipes instead of the SS lines, are you reffering to hard pipes?
Re: My fuel setup, you comments are welcome and appreciated. (lshatchturbo)
Nova_Dust
10
08-10-2006 08:16 PM
