Greddy AF o2 in stock o2 place...bad idea?
Old 07-15-2002, 01:03 AM
New User
DuNkiN's Avatar
Default Greddy AF o2 in stock o2 place...bad idea?
like the topic says, is it a bad idea? cause the instructions said it can be put there and i wouldnt have to drill
Old 07-15-2002, 02:42 AM
Dee
Dee's Avatar
Default Re: Greddy AF o2 in stock o2 place...bad idea? (DuNkiN)
Eventhough the sensor is heated Greddy recommends placing it within 18" of the header flange. If you want to use the the sensor as your main o2 sensor you might want to visit the Hondata page and download the instructions for the Motec PLM install. I have been using a Greddy AF meter as my main sensor for datalogging for more than 8 months without any problems. Do you have the english instruction manual for the AF meter?
Here's my placement!
Old 07-15-2002, 04:35 AM
rjardy's Avatar
Default Re: Greddy AF o2 in stock o2 place...bad idea? (Dee)
VERY nice
Rob
Old 07-15-2002, 09:08 AM
New User
DuNkiN's Avatar
yeah i have the instructions in english, i want a egt so thats why i dont want want to weld the flange in, just use it temporarily because i have it. Whats your meter reading at? thanks btw i have a greddy kit
Old 07-15-2002, 04:33 PM
Dee
Dee's Avatar
Using a EGT and AF meter together will give better results than just using one of them. AF meter bung has absolutelty nothing to do with the EGT position so you kind of lost me there. Do NOT put the EGT in the dp. What are my readings? Stoich w/o boost and 12~12.5 under boost!
Old 07-15-2002, 06:19 PM
New User
abraunb16's Avatar
Hey Dee, I was told to run the EGT in the DP. I guess some of the Supra guys are having or had problems with the EGT probe breaking in the mani then screwing up the blades/turbo. What's your take? Or anyone else for that matter. Later Allen
Old 07-15-2002, 07:05 PM
Dee
Dee's Avatar
Default Re: Greddy AF o2 in stock o2 place...bad idea? (abraunb16)
The probe coming out of my ex housing is for the EGT. That's the common spot here in Japan when using a stainless manifold. Temps in the dp are a lot cooler than the temps in the manifold and ex housing.
Old 07-15-2002, 07:22 PM
New User
abraunb16's Avatar
I'm running the Maxrev logstyle mani, so it's pretapped for the EGT in the #3 primary. I just had a bad Datalink with my Greddy so I'm unable to use it yet. I just didn't know about this whole breaking in going into the turbo rumor and with my luck with Greddy I'd be the one. Later Allen
Old 07-16-2002, 10:19 AM
PROFILES2000's Avatar
that almost exactly where i mounted the "bunghole" heh for my greddy 02
sundownz
03-09-2007 05:26 AM
speedymon
03-02-2004 02:33 PM
speedymon
09-10-2003 04:16 AM
nosintegra92
06-06-2002 08:46 PM
JM Performance
11-22-2001 10:57 AM
Quick Reply: Greddy AF o2 in stock o2 place...bad idea?
