what parts do i need to make a fitting fit on the oil pan? dont want to weld it on!
ok i have a 10an male weld fitting but i was thinking i could use a flare union w/ some locknuts or maybe a AN port adapter w/ an oil ring seal, just dont want to have any leaks. whats a good weldless method? ill be using 10an fittings btw. earls parts is what im looking for....
Guest
Posts: n/a
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (DeeJay)
here's what you do. Drill about a quarter inch hole in your pan. Take a large punch and hammer it into the hole. The punch will flare the metal inwards to give you more surface for threads. Use a 3/8 pipe thread tap on the flared metal and screw in your fitting. I did it and I'm leak free, no JB weld.
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (filetofit)
No JB weld (sucks)
Take it to a welder. Remember to clean oil pan for him first
Its the best way IMO
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (SO3Burner)
Just spend $25 and have a machine shop weld it for you. Money well spent.
Unceasing Measure
make sure to loctite or teflon tape that badass before screwing it in for extra certainty
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (Archidictus
here is a helpfull link, there is no reason that this would not work, im welding mine, but then again i have a machine shop at my disposal! http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
HTH
Rob
HTH
Rob
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (lucas569)
Use a bulkhead fitting with two oiltite washers. You'll be leak free. It's what bulkhead fittings were designed to do.
Re: what parts do i need to make a fitting fit on the oil pan? dont want to weld it on! (bruthaboost
thanks everyone i ordered some bulkhead fittings plus some union fittings w/ the o-ring seal and plastic wahser PLUS i have the 10an male weld flange that i bought from arturbo if everything i try doesnt work
i got them from http://www.anplumbing.com
1 -10an bulkhead (cut down the insise for clearance), 2 7/8ths washers, blue rtv, and a big hole.
who's oil pan is that, I think the fitting is too low on the pan and why is it on the drain plug side of the pan?
Where would i be able to find these fittings. I jb welded mine and it leaks
It's an oil pan from a cl I believe.
But how come your return enters on the backside of the pan?
Tom
Tom
your fitting is tapped too low in the pan and should be at the front. otherwise it looks clean, not like my JB weld masterpiece - of -****.
Yeah its a CL pan. Everyone says its too low but it works great.
Had to go to the back of the pan since its an accord kit on a CL...downpipe in the way.
Think about it...the turbo is a good 18" higher than the -10 fitting. That whole line would have to fill with oil before backing up into the turbo.
Local hydraulics store. Any shop that deals with custom hoses should know AN stuff. AKA....JIC fittings.
-10 bulkhead, -10 90 degree female/barbed
$15
$15
