Bolting the turbo the the manifold question...
New User
My problem right now is the manifold is threaded and also the turbo.. the holes line up good... do i drill out the turbo threads and then bolt it or how does the screw just go thru? what do you guys do? thanks
Re: Bolting the turbo the the manifold question... (Integra_Boi)
what turbo and manifold are you running? i would just drill one of the two out, tour choice really.
Rob
Rob
On my revhard, the manifold is threaded, and the turbo flange is not..
Just make sure you use lock washers (Revhard kit came with them)..
New User
Re: Bolting the turbo the the manifold question... (falconGSR)
i got it off bpmotoring.... well the it says garrett on it.. i dont know bout the compressor side..
hmm...I never thought about that. both are threaded on my set-up too...I think I'd have to drill ou the threads on the turbo cause I don't think they'll line up with the manny, even though they're the same pitch. crap. do I need to do this?
RubenPrelude
02-28-2008 07:34 AM
