Who here has cracked their stock sleeves?
I was wondering who here has actually cracked their stock honda sleeves? And if so, how many lbs were you running and what kind of tuning did it have?
New User
Re: Who here has cracked their stock sleeves? (BG Boost)
oooh oooh, I wanna be first in on this thread
I cracked my bored .20 over Honda sleeves. It was due to Crower's crappy *** cams breaking in four pieces (quin overhead cam baby) dropping a valve and smashing the whole motor into bits. Boost level = atmospheric.
Re: Who here has cracked their stock sleeves? (VaporTrail)
Just check out my avatar It was a B16 block. 9200rpms on Gude valvespring (ie. they were stock ) . Broke the liner, sleeve, rod, piston, head, and bent the crank Oh, @0psi. Pretty impressive...I saved the parts as a memorial.
That was back when I knew nothing...after years of research, asking question, trial and error I have learned one thing since then...I have learned you can never know enough.
[Modified by DSF, 12:25 PM 7/12/2002]
i've got a pic some where of what some shitty *** Toda cams did to a JDM ITR block & head. Cams shreadded the timing belt causing car to jump time bent 1 rod & destroyed combustion chamber. put hole in #1 piston & cracked cylider wall in 2 places
Cracked number 3 on my LS. 13psi seat of my pants tuning. dumb dee dumb dumb DUMB!!!
I have had great exercise for 3 months (walking).
[Modified by Doodoo, 4:27 PM 7/12/2002]
Re: Who here has cracked their stock sleeves? (APEX i GSR)
Re: Who here has cracked their stock sleeves? (Etylorcen)
Toda cams? I bet it was due to an improper install...
Re: Who here has cracked their stock sleeves? (91CivicSi)
OT, but I think Toda cams require an aftermarket belt like Power Enterprises. Coquinn's Honda belt broke with Toda Cs.
[Modified by gsR-T mode, 11:39 PM 7/12/2002]
how does the car sound when you crack a sleeve...does it smoke white smoke pretty bad?
Re: Who here has cracked their stock sleeves? (MiraiZ)
Cracked number 1 cylinder wall. Stock B16A2, t3/t04b, 12psi. One too many 140mph runs White smoke covered a good 1/8th mile when it went.
fusion645
12-31-2009 08:40 PM
b20vtech
10-02-2007 02:14 PM
jon3zy
04-19-2007 04:55 PM
hondaapi
10-29-2006 06:29 AM
