car stalls when slowing down
Old Jul 12, 2002 | 06:30 AM
Kevin's Avatar
Default car stalls when slowing down
The car is a 00 Civic si turbo with 9 to 1 CR. The car stalls every now and then when you slow down, push the clutch in and cruise to a stop. I have tried everything to try and stop it but it still happens. It happened enough that the starter eventually went from restarting the car all the time.
Im wondering if i can adjust the throttle cable to raise the idle and stop the car from dying. I figured the lower compression might be causing it and the idle needs to raised a few hundred RPM. The thing is that some cars dont like this way of raising the idle due to the TPS. Im not too familiar with Hondas and how you guys raise the idle without having a standalone.
Ideas are appreciated.
Old Jul 12, 2002 | 06:39 AM
CovertFI's Avatar
Default Re: car stalls when slowing down (5speedv6)
what is your full setup? are you not running you iacv
Old Jul 12, 2002 | 06:47 AM
Kevin's Avatar
Default Re: car stalls when slowing down (CovertFI)
endyn 9 to 1 rollerwaves
eagle rods
cometic hg
greddy turbo kit
type 23 intercooler
act 3 puck clutch
stock head
stock intake manifold and stock throttlebody
still using the IACV which was replaced and still had the problem
new o2 sensors, new starter
Old Jul 12, 2002 | 06:50 AM
CovertFI's Avatar
what fuel management unit are you using?
Old Jul 12, 2002 | 06:56 AM
Kevin's Avatar
blue box, walbro in tank, AEM FPR
We are waiting on either a Hondata or AEM standalone.
Old Jul 12, 2002 | 06:57 AM
CovertFI's Avatar
do you think you might be running rich? does it stay running if you give it gas when you stop?
Old Jul 12, 2002 | 06:58 AM
Kevin's Avatar
i gotta add that it stalled before we added the walbro in-tank.
Old Jul 12, 2002 | 06:59 AM
Kevin's Avatar
yeah, if you blip the throttle it will stay running. It dies if you let out the clutch when slowing down and the revs drop suddenly and it doesnt happen all the time. Its really annoying that i cant figure this out.
Old Jul 12, 2002 | 07:31 AM
stizzit's Avatar
Mine does the same thing heh, i've just learned to heal toe for now, pretty damn good at it!
Actually tho I always thought i was running rich but taking out fuel didn't help much so maybe its my TPS. ?
Old Jul 12, 2002 | 07:35 AM
2000Si-at-UK's Avatar
Default Re: car stalls when slowing down (stizzit)
I have roughly the same setup, and my car has similar problems whenever my plugs become fouled. It also doesn't want to start sometimes. But as soon as I change the plugs, it runs like it should.
Old Jul 12, 2002 | 07:40 AM
Sleeper's Avatar
You could try reseting the idle. If that doesn't work try adjusting the TPS. If you never get the .45v at closed throttle the ecu won't cut fuel and it'll want to stall coming to a stop.
Old Jul 12, 2002 | 09:06 AM
Kevin's Avatar
Default Re: car stalls when slowing down (2000Si-at-UK)
The plugs are brand new as well.
Kevin's Avatar
Default Re: car stalls when slowing down (Sleeper)
im just gonna adjust the idle and see what happens. Thanks for the help guys.
Old Jul 12, 2002 | 09:08 AM
reXem's Avatar
My friends Focus ois doing this right now but it only started happening when we added his AEM CAI so we figure its the culprit.....dunno why though.....
Old Jul 12, 2002 | 12:54 PM
SilverS's Avatar
crap mine is doing this when the motor is cold in the morning....
its been doing it for 5000 miles now.....
ever since i did a valve adjustment, im not saying thats what did it, just happend around that time....
changed the IAC, Plugs, reset the ecu and did idle learn.... and car still does it....
B_Swapped93
Feb 27, 2013 09:05 AM
Civicfanatic_09
17
Jul 16, 2012 12:04 AM
Upper Hand
Jun 12, 2008 05:02 PM
ringgold
13
Aug 9, 2005 10:03 AM
99b18
Nov 11, 2004 05:36 AM
