What do you use to keep your engine temps down?
Old Jul 12, 2002 | 08:11 AM
RATEDR's Avatar
Default What do you use to keep your engine temps down?
Anybody run a aftermarket thermostat or radiator car? What about Fluidyne radiators?
I have a Billions thermostat right now and thinking of getting the Mugen radiator cap and the FAL radiator fans. Im thinking anything to help keep temps down is a good thing.
Other setups?
Old Jul 12, 2002 | 08:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What do you use to keep your engine temps down? (RATEDR)
Dont get one unless you are over heating. You are over thinking everything and remember to KISS.
art
Old Jul 12, 2002 | 08:24 AM
VaporTrail's Avatar
New User
Fluiddyne
Spoon radiator and cap
Redline water wetter
FAL fans
None of which are absolutely needed, but if you gotta have the baddest of the bad, those are it.
Old Jul 12, 2002 | 08:26 AM
DSF's Avatar
DSF
Default Re: What do you use to keep your engine temps down? (Arturbo)
More people should live by this rule...including me
[Modified by DSF, 12:26 PM 7/12/2002]
Old Jul 12, 2002 | 08:29 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What do you use to keep your engine temps down? (DSF)
your bank account will love you for it.
Old Jul 12, 2002 | 08:41 AM
Anubyss's Avatar
Is water wetter really worth putting in the radiator? I bought one bottle but am kinda wondering if it's worth putting it in an aftermarket radiator (soon to be installed).
Old Jul 12, 2002 | 08:42 AM
VaporTrail's Avatar
New User
Default Re: What do you use to keep your engine temps down? (Anubyss)
like giving a dead man an enema - it may not help, but it sure as hell ain't gonna hurt.
Old Jul 12, 2002 | 08:45 AM
DSF's Avatar
DSF
Default Re: What do you use to keep your engine temps down? (VaporTrail)
LOL
That's about the funniest thing I heard today!
Old Jul 12, 2002 | 09:40 AM
Speed PHreak's Avatar
Forget the water temp, stock usually does just fine. If it doesn't a lower temp thermo and fan switch will suffice.
I'd look into lowering your oil temps. Oil coolers can be put together for relatively cheap and go along way towards keeping turbo'd engines happy. Oil is the life blood of your motor, and the heat of a turbo is rough on the oil. Keeping your oil cooler will help the life of your engine and keep the overall temps oil AND water lower.
After I installed my oil cooler, I noticed a 5~10 degree drop on average in water temp.
HTH
~steven
Old Jul 12, 2002 | 09:42 AM
DSF's Avatar
DSF
Default Re: What do you use to keep your engine temps down? (Speed PHreak)
Huh, thanks. I always wondered what effect an oil cooler would have on water temps.
Old Jul 12, 2002 | 11:58 AM
RATEDR's Avatar
Which oil cooler set up are you running.
Old Jul 12, 2002 | 12:27 PM
Custom oil cooler setup:
Tru-Cool oil cooler (TRU-L7B, 24 row) ~ $50
Canton billet sandwhich adapter plate ~$50
12 ft of 15/32" crank case ventation hose. ~ $10
(4) 1/2" NPT --> 1/2" Barbed hose fittings ~ $5
Total cost was about $125
http://www.racerpartswholesale.com is where I got the oil cooler and adapter plate from.
~peace
Old Jul 12, 2002 | 01:10 PM
accordfreak's Avatar
how does koyo and fluidyne radiators compare?? any comments?? experiences??
what would you recommend??
also, does those braided radiator hose cover help?? or are they mostly for show?
thanks
[Modified by accordfreak, 10:14 PM 7/12/2002]
Old Jul 12, 2002 | 06:03 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you really want to save money, instead of water wetter use a a tea spoon of your favorite dish washing detergant. No lie! Does the same thing as WW and you can add the pretty purple color if you want to.
art
Old Jul 12, 2002 | 06:55 PM
rondigs's Avatar
Speaking of radiators.... My radiator(Stock 95 teg) has developed a very minimal leak. However, I assume it will progressively get worse. Im in the process of putting together a fully built ls/v turbo(60-1) motor. Should I consider replacing the stock radiator(due to fitment issues and the fact its leaking) or figure out how to seal it up. Im leaning towards replacing it-any suggestions.
Old Jul 12, 2002 | 07:20 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
~peace
Wow, that sounds great, I was goign to get a oil cooler once I got my turbo put in, but I didn't know what to get.
Have ever heard of these "Set Rabs" Oil coolers or something like that?
What do you guys think of the pricey Greddy Oil Cooler?
How about the B&M. I'm trying to figure out which one I want.
1 2 NV
Jan 31, 2007 08:38 PM
projectM
17
Feb 14, 2003 12:53 AM
94GSRRacer2
May 8, 2002 08:04 PM
EGh22aEG
Jan 9, 2002 06:37 PM
