avc-r help!
Old Jul 12, 2002 | 10:12 AM
311's Avatar
311
Default avc-r help!
I need to know how you set the boost on an avc-r. i have the instructions, but i just want someone to tell me how to do it in plain english. thanks.
Old Jul 12, 2002 | 10:25 AM
TurboIntegra's Avatar
Default Re: avc-r help! (311)
1) Set your desired boost level.
2) Set the duty cycle required to get the boost you want.
Easy.
Oh and the instructions make it very clear on what to do.
Old Jul 12, 2002 | 11:20 AM
TypeC's Avatar
Default Re: avc-r help! (TurboIntegra)
You do a little more than that.
first set the learn gear, and follow the instructions.
Then set the boost:
boost 1.25 (or whatever you need it at) duty 56% (ie don't change the value per rpm yet, just put the number in itself)
feedback setting 9, 8, 6, 5, 4
Do a couple long 3rd gear pulls so the computer can learn the boost (duty) curve. Once it's learned, it'll show "**" instead of "56%" in the duty cycle part, and you can change you boot to peak from there and it should be good. You can also increase the duty cyle in the lower rpms (before you get full boost) to increase spool.
You'll want a higher start duty (like 20%) in 1st gear, and lesser in the others. The percent depends on your setup and turbo.
hth, -C
[edit] found my old post:
https://honda-tech.com/zerothread?id=181458
[Modified by TypeC, 3:07 PM 7/12/2002]
Old Jul 12, 2002 | 11:44 AM
311's Avatar
311
Default Re: avc-r help! (TypeC)
very helpful, thanks!
Old Jul 12, 2002 | 01:14 PM
Audi A4's Avatar
some complicated ****, i ll jsut adjust the screw.
Old Jul 12, 2002 | 01:42 PM
TypeC's Avatar
Default Re: avc-r help! (DRAG lll INTEGRA)
Yeah, but it works wonders. That 10-15 min you spend configuring it, will get you full boost in each gear, instand spoolup (turbo permitting), not spikes, no boost drop off, and a custom boost curve(s) to your liking (traction control, etc).
Basically, iT 0wnz Jo0!
Old Jul 12, 2002 | 01:46 PM
TypeC's Avatar
(still going off)
It's kinda like when the first calculator was made. You were the guy who said "some complicated ****. I'm sticking with my abacus."
JFWY
kmaz93da
Jun 2, 2010 06:24 PM
h2b_sedan
Engine Management and Tuning
Nov 29, 2009 05:45 PM
Project X
Jul 17, 2008 08:38 PM
turbo boost
May 6, 2008 04:07 PM
bigbadboy
Sep 16, 2007 08:05 PM
