Good sixe turbo help??
Old Jul 14, 2002 | 04:36 PM
civictyper85's Avatar
Default Good sixe turbo help??
I have a 99 LS with a 94 GSR motor...Planning on running a turbo with stock internals...I was going to run a max rev manifold with a t4 60-1 turbo but found out that i would have to remove ac...i need either a manifold that will fit a t4 60-1 turbo and retain ac or best t3/t4 turbine and compressor sizes for my goals...I am looking to run about 320 to 350 whp...running low low 12 sec to hig 11 sec 1/4 mile passes...no drag kit im going custom so that's not an option...i am also trying to found out wether sfp manifold can run the 60-1 setup and retain ac...ALL HELP APPRECIATED...THANKS...
Chris
Old Jul 14, 2002 | 05:16 PM
b18turbocivic's Avatar
Default Re: Good sixe turbo help?? (civictyper85)
I dont know about all that with stock internals.And from what i've read and from the pics some of the guys here have posted if you want to run the 60-1 you most likely are goint to have to sacrifice the a/c....that's a big s.o.b.
check this thread: https://honda-tech.com/zerothread?id=182303
tito1324
Mar 6, 2017 10:16 AM
eljah0426
Mar 7, 2010 08:37 PM
b18c1wes
Jan 5, 2005 01:48 AM
Crackerballer
Mar 24, 2004 07:06 PM
tygsr
Jan 21, 2003 12:12 PM
