H22 boost...JDM or USDM?
Old Dec 25, 2002 | 02:41 AM
paulzy's Avatar
Default H22 boost...JDM or USDM?
I'm gonna go through with teh h22 swap that turbo it for teh dummer to cool me off...
I have a choice between the JDM(10.6:1) and the USDM(10.0:1)...
JDM makes 10 more horses and 5 more ft/lb
JDM: 200hp 161tq
USDM: 190hp 156tq
do you guys think it would really matter? Is .6 more compression really gonna hurt that much? I mean, ITR's are boosted, but they can probably hold more boost than h22a's though
[Modified by paul_vang, 3:41 AM 12/25/2002]
Old Dec 25, 2002 | 03:37 AM
GOLDBERG's Avatar
Default Re: H22 boost...JDM or USDM? (paul_vang)
isnt the h22a-R 225hp?
Old Dec 25, 2002 | 05:08 AM
bambooluv's Avatar
Default Re: H22 boost...JDM or USDM? (GOLDBERG)
yes the h22-r is 225.
Paul I would go with the jap spec motor just from my
observation with all these jap specs that I have seen much more sturdy
for all motor or boost. The pistons arent domed that much more on the
jap spec and should be fine. just my 2 cents good luck man-pdang
Old Dec 25, 2002 | 01:41 PM
flip1199's Avatar
Default Re: H22 boost...JDM or USDM? (bambooluv)
i think u mean the h22 type S and that has 220hp
Old Dec 25, 2002 | 02:17 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: H22 boost...JDM or USDM? (flip1199)
jap spec obd 1 is the way to go. Its a closed deck block. we have made 667hp on our block with just cheap 200.00 sleeves. the block is solid. by the way we sell them 1100.00+ shipping. Thats motor only.
Old Dec 25, 2002 | 02:56 PM
paulzy's Avatar
Default Re: H22 boost...JDM or USDM? (MotorMatrix.com)
I'm looking for a sfull swap and was gonna pick it up from HMO
or the full front clip form Jspec
the thing I'm wondering is...is that would it be worth the trouble of having a full front clip and ripping the motor out of there when it gets here. It's only and extra 50 bucks from Jspec
[Modified by paul_vang, 3:59 PM 12/25/2002]
Old Dec 25, 2002 | 03:15 PM
fastludeh22's Avatar
usdm. if your going to do a boosted h22 right, you will need to rebuild and change everything that is different on the 2. so use the money saved on it to rebuild it. h22a1 is usdm closed deck.
btw- i have an h22 4 sale, link below
Old Dec 25, 2002 | 04:05 PM
paulzy's Avatar
Default Re: H22 boost...JDM or USDM? (fastludeh22)
it's gonna remain stock for now
Old Dec 25, 2002 | 04:11 PM
GraphiteAccord's Avatar
Motormatrix, what sleeves are you running?
Old Dec 25, 2002 | 04:16 PM
I am a bad person
Default Re: H22 boost...JDM or USDM? (GraphiteAccord)
we are running sleeves from autoraceparts.com. they are ARI sleeves. remember you cannot run an aftermarket JE piston on an h22 w/o sleeves.
Old Dec 25, 2002 | 09:43 PM
paulzy's Avatar
HOw do you like them? How long have you had them in the motor?
I was thinking about those too since I've bought form ARI in the past and had great service towards me...
have you ever tried GE or Darton? HOw would you compare the ARI sleeves to these 2 companies
Old Dec 25, 2002 | 09:46 PM
VaporTrail's Avatar
New User
the jdm pistons are noticibly weaker than their usdm counterparts. Ring lands are smaller...I'd go with the usdm personally.
Old Dec 25, 2002 | 10:06 PM
I am a bad person
I would say for a closed deck block they would work as good as darton or ge for the most part. if it was an open deck i would probably go with darton or ge. we have had them in our motor for more than 4 events and have boosted 30+psi on them.
Old Dec 25, 2002 | 10:18 PM
paulzy's Avatar
thanks for all the input guys
Old Dec 26, 2002 | 07:34 AM
bgod's Avatar
ringlands are equally weak on the jdm and usdm motors. this is the weak link of the h series motors. the rings and ringlands. the ringlands will crack like pretzels as many boosted h22a owners have found out.
but the jdm spec motor is a far better choice for an n/a set-up until the summer when you go boost. then you can rebuild at that time. i'd go with the jdm motor if possible.
4th gen. preludes with bolt-ons, clutch, flywheel have been known to go 14 flat in the quarter mile or very close to with a jdm motor.
Old Dec 26, 2002 | 12:00 PM
chidoks's Avatar
wow, ari sleeves here i come
twiztid00002
Feb 18, 2009 04:48 AM
HandoEX
May 3, 2006 03:12 PM
BoOstInHaRd
Mar 26, 2005 12:44 PM
nema741
Nov 14, 2003 03:55 PM
whitemike1644
Mar 19, 2003 05:36 PM
