Need Help Building My Ignition System for N2o
Old Dec 25, 2002 | 09:15 AM
integranator's Avatar
Default Need Help Building My Ignition System for N2o
I'm not sure what to build my ignition setup with, since i'm going to be using a 100shot direct port. What Do you think i should be running? (Timing retard, msd, plugs, plug wires) All that good junk. Nitrous junkies please help!!
Old Dec 25, 2002 | 09:22 AM
b18bturbo's Avatar
Default Re: Need Help Building My Ignition System for N2o (integranator)
we used to use the crane hi6tr unit with adjustable retard back inthe day worked well. Use one step colder plug and factory or NGK wires.
[Modified by b18bturbo, 12:22 PM 12/25/2002]
Old Dec 25, 2002 | 09:24 AM
rOby's Avatar
u just need one thing, msd digital 6..its got all the stuff u need. retard, 2 step...
gotta get a coil w/ it also..hvc or crane version.
ur other option is like a 6a, 6al, sci or whatever basic box. only prob is then u need to buy the n20 retard and all other goodies.
no need for wires.
get a msd cap, digi 6 , and ngk bkr7e and ur set.
merry xmas
Old Dec 25, 2002 | 09:26 AM
Default Re: Need Help Building My Ignition System for N2o (rOby)
ngk bkr7e? is that the part number for the plugs? Cas' I assume i need 2step colder plugs, correct?
Old Dec 25, 2002 | 09:29 AM
b18bturbo's Avatar
i think the part number for th ngk are 1095 if i remember correctly the ngkbcpr7es11 or ngk bkre711
Old Dec 25, 2002 | 09:32 AM
Default Re: Need Help Building My Ignition System for N2o (b18bturbo)
What Do you think of this-- This is what i was planning on running:
MSD Plug Wires, NGK 2 step colder platinum plugs, msd digital 6 as Roby Explained above, and a coil of some brand (prolly msd). Do i need a new cap?
[Modified by integranator, 7:14 PM 12/25/2002]
Old Dec 25, 2002 | 11:36 AM
anyone else?
Old Dec 29, 2002 | 10:35 PM
Rah Rah's Avatar
Part no. 6097 for the BKR7E (2 steps colder), got a box sitting right in front of me.
Old Dec 29, 2002 | 11:04 PM
dvp95's Avatar
Default Re: Need Help Building My Ignition System for N2o (sando112)
i thought the 2 steps colder ngk plug was zfr7r (something close to that). I was told that so thats what i got. Actually ngk told me that too, but whats the diff between the b... and the zf....plugs?
Old Dec 29, 2002 | 11:12 PM
Rah Rah's Avatar
Default Re: Need Help Building My Ignition System for N2o (dvp95)
zfr's are the VPower line of plugs. They are projected style plugs, which you don't want for nitrous. For example, my 92 LS's stock plugs are ZFR5-11 (copper) and PZFR5F-11 (platinum). The "5" is the heat range. For NGK's the higher the number, the colder the heat range. Thus, the BKR7E's are 2 steps colder than stock. Also, The BKR's are non projected style tips which is what you want for a turbo or nitrous application.
Old Dec 29, 2002 | 11:16 PM
Rah Rah's Avatar
http://www.ngksparkplugs.com/techinf...tnumberkey.pdf
Old Dec 29, 2002 | 11:47 PM
dvp95's Avatar
son of a bitch thats what people told me to buy! All this time i thought i had the right plugs, but i guess i didnt. Ill be paying napa a visit soon. Thanks though!
Old Dec 30, 2002 | 02:38 PM
Rah Rah's Avatar
The problem is that there are a lot of people that don't know much about n20. Here's a link from NOS:
http://www.holley.com/HiOctn/TechSer.../NOSTech3.html
It has some good info. Scroll down to the part about spark plugs. I've gone through a melted valve and a melted piston with my nitrous kit. So you could say that I have a little experience with it However, now that the turbo's going in next spring, the kit will be retired.
[Modified by sando112, 6:43 PM 12/30/2002]
Old Dec 30, 2002 | 08:15 PM
dvp95's Avatar
Ive run my nitrous system on my h22a for about 10-15 runs now at a 50hp shot. The plugs look kinda gray...what does that mean? Heard it was normal, but is it detonation?
Old Dec 31, 2002 | 09:33 AM
sweet's Avatar
my plugs almost always looked Gray, which is ok but a bit on the lean side if it's light Gray/White in color. a darker Gray to Mocha color is just right. if there are specs of silver and white stuff then that's detonation. you should hear predetonation while injecting if there is any. if real mild you may not.
Old Dec 31, 2002 | 09:37 AM
sweet's Avatar
MSD Digi 6, MSD cap, HVC coil, stock or Magnecor wires, NGK BKR7E-11 plugs gapped around .035". from Summit Racing the plugs are #1283 ($2 each), #7 in heat range which is 1 step colder than the DOHC VTEC plugs. may be 2 steps colder than the stock B18B plugs, but i can't remember if they were #5 or #6 plugs.
BTW, what DP system are you using and what fuel upgrades do you have already?
Old Dec 31, 2002 | 10:12 AM
highbrid's Avatar
Default Re: Need Help Building My Ignition System for N2o (sweet)
special order some autolite racing plugs from checker, part # ar3933, they work great
Old Dec 31, 2002 | 10:32 AM
PM-Performance's Avatar
on my set up i ran 100 shot too
i still have the igntion set up for boost now
but my set up works great
MSd dig 6+ with all its features,
msd wires
msd cap
msd blaster ss coil( which was recommended from MSD direct for the digital series igntions)
and a set of NGK bKR7e11 plugs
my set up worked great
Old Dec 31, 2002 | 04:48 PM
Rah Rah's Avatar
Default Re: Need Help Building My Ignition System for N2o (itr206)
Did anyone check out the new kit from Nitrous Express? It has a fuel rail included with the kit and no solenoid to mount. It looks pretty good.
Old Dec 31, 2002 | 06:04 PM
rOby's Avatar
the solenoids mount directly onto that rail. theres no way to elliminate solenoids!
Old Jan 1, 2003 | 06:51 PM
sweet's Avatar
yeah but the new N2O injection kit i'm gonna use doesn't need solenoids, and it supports a 300 shot!!
SOHC SPEED
Jul 20, 2008 06:45 PM
cdk001
Mar 30, 2006 09:57 PM
DarkDragon
Jan 30, 2005 08:33 AM
StageIIIhb98
Dec 17, 2002 05:58 PM
Civic VTi
Mar 7, 2002 06:06 PM
