Mounted my ic today . . . kinda depressed
well i mounted my ic , it looked like it was gonna be a descent size, but guessed wrong .
I dont like it at all , its too short legnth widse and to high the whole bottom half is begin blocked by my bumper it sticks out a ahir under the lip too , so i gott watch my driving now .
i tried to think of diff ways of mounintg it , but no luck
i just bolted up to the bumper support
Re: Mounted my ic today . . . kinda depressed (90crxsi)
i thought about it , but i dunn o , i dont want to fick with the safety of my motor if i get hit in the front or something . . . that might be my only choice.
1 Post
Re: Mounted my ic today . . . kinda depressed (itr206)
I had to cut my front bumper support, that metal bar that goes across the front of the car. I didn't completely cut it off, I just left a bit at the top so that the bar is still connected up. Ended up looking something like this:
And it still wasn't enough.. the evo 5 intercooler is just too damn tall, it still sticks out underneath the bottom of the bumper
Yours doesn't do that, so I'd count yourself lucky. Just cut that metal bar about 2-3 inches so you can move it up higher.. i'm sure it'd look better.
[Modified by turbopanda, 8:51 AM 12/23/2002]
Re: Mounted my ic today . . . kinda depressed (Farnsrocket)
what are the dimensions of this thing?
it doesnt look bad..just keep it, who cares..if its fast its fast
i cut the bumper cover tough, i just didnt want to cut the actual bumper support though, for saftey reasons.
mine does stick out under the bumper a litytle , but har dto notice. if i took my lip off, it would look like pandas.
Re: Mounted my ic today . . . kinda depressed (integra-modder)
hey itr, i have the same IC i think, thats a spearco core right? if so then yeah i do...i was kinda depressed about how far it hangs down too, it flows really nice though
That's look similiar to a Maxrev IC. Mine fit just like yours did at first, hanging down about 1.5" inches below the front lip. I did not want to cut my bumper support either but in the end it was the only choice I had. It came out good and I am happy with it now.
Before exterior:
After:
HTH.
Justin
[Modified by justinCO, 7:51 PM 12/22/2002]
Before exterior:
After:
HTH.
Justin
Re: Mounted my ic today . . . kinda depressed (justinCO)
what did you use to cut it ?
i fdont think like a saw zaw will work ? maybe like one of those air rotary tools?
i dunno im gonna see if i can get something cut away a little at it and see what happens . . . . . thanks for the pics Justin
Re: Mounted my ic today . . . kinda depressed (lilxvtecxpwr)
I've got the same IC, and I really don't mine hanging down below my lip. So you suggest that I cut into the bumper support when installing it?
One thing that I saw once was a kind of skid plate thing on a turbo m3 that used to come into my old gas station (sold race gas). He had his front lip re-made out of carbon fiber, but instead of just ending after going back a half inch or so, he had it extended to about 6 inches back, covering the bottom of his IC, and he had them make it thick too, like 3/8" of fiber, and he has it bolted in like 6 places. He says he's been road racing and hit all kinds of debris that would normally have left him with a giant hole, but the carbon fiber lip/skid plate seems to work. Just a thought, it might work. Be damn expensive to make, though.
Looks like when the IC goes on, I'll be cranking up those coilovers I haven't adjusted in over a year
[Modified by VerbalKint, 7:26 AM 12/23/2002]
Justin
i think it looks fine other than that it hangs a lil too low.
this should be a concern in case you bottom out, you dont wanna trash a nice expensive ic cause you hit a bump, they do bend easy.
i ran into this same problem installing this ic on my friends teg, i did what justin did but my friend kept bithing about the safety issue (*****! j/k )
so i cut a piece off an old mountain bike frame he had in the garage and drilled some holes in it to use some bolts and lock nuts so that it could be held in place firmly (look at the 4 big holes on top in justins pic)
a hollow tube is very strong and w/ this in place it prolly made the bumper support stronger than stock.
Re: Mounted my ic today . . . kinda depressed (lucas569)
actually mine is 28.5x8.5x3
but yea im worried about bottoming out . i have the coilovers above stock right now so its high, but when it gets warm i usually slam the hell outta it .
Damn, that thing is 28 inches wide? Mine is 20x7x3.5 and I was going to say it looks just like yours and I actually like the way it fit.
M
M
Re: Mounted my ic today . . . kinda depressed (01ITR#700)
that measurement is with endtanks.
the core is like 23x8.5x3 or something like that
I have the exact same intercooler Justin has. My name is Justin too. except I have a 94-97 bumper - do those bumpers hang lower than the 98+'s? I dont want to cut anything I don't have to.
Charlie Moua
07-08-2011 10:19 AM
Charlie Moua
06-28-2011 03:17 PM
sporkcrx
09-05-2003 09:42 AM
