How to do a Compression test?
Old Dec 22, 2002 | 11:23 PM
FredoSP's Avatar
Default How to do a Compression test?
hey guys, I want to know. I'm going to Pep Boys tomorrow and getting the gauge. Also how does this differ from a leak down test. I want to have a clue whats going on before she goes to 7 psi on Hondata
Thanks
P.S. Sorry for the noob question, but I want to get my hands dirty!
Old Dec 22, 2002 | 11:32 PM
Tyler H's Avatar
Default Re: How to do a Compression test? (FredoSP)
Compression test is actually way easier than a leak down test. First, get the engine up to operating temperature. Second, remove all four spark plugs. Third, either unplug all four fuel injectors or the distributor (injectors will not fire without a cam signal). You don't want raw fuel being injected and blown out of the spark plug holes. Fourth, install compression guage on cylinder one. Depress gas pedal all the way to the floor and crank the engine. I do it until the needle stops moving, but some do it for a set number of cranks. Rinse, lather, repeat. That's it!
Tyler
Old Dec 23, 2002 | 04:26 AM
Charlie Moua's Avatar
Default Re: How to do a Compression test? (Tyler H)
where to get one and fro how much? I don't trust anything from pepboys!
Old Dec 23, 2002 | 08:15 AM
dasher's Avatar
Default Re: How to do a Compression test? (Charlie Moua)
15-24.99
Trust pep boys, discount or advanced auto parts .... this is a very simple tool... they all sell fairly reliable compression testers...
Old Dec 23, 2002 | 08:26 AM
CzanSOHC's Avatar
Default Re: How to do a Compression test? (dasher)
sears or jegs....$30.00
Old Dec 23, 2002 | 08:47 AM
TurboedGSR's Avatar
i'd let the engine cool down for at least 5-10 minutes, you dont want to strip the threads. also you can take out the 15 amp (i think its 15amp, blue right on the corner)pgm fi fuse.
Old Dec 23, 2002 | 10:07 AM
Default Re: How to do a Compression test? (TurboedGSR)
ANYone have an
(actron) compression tester from Sears? just want an accurate reading.
Old Dec 23, 2002 | 12:30 PM
what about SunPro? any good?
Old Dec 24, 2002 | 01:58 PM
FredoSP's Avatar
thanks guys, I did it myself, it went well
Old Dec 25, 2002 | 09:48 PM
FredoSP's Avatar
FYI ...
190 180 190 210
Old Jan 11, 2003 | 05:52 PM
Fuster_Cluck's Avatar
Tyler
So, you put the accelerator to the floor and start the motor? Do you hold it to the floor until the RPM's get close to red-line??? When you say "until the needle stops moving" ...you are referring to the compression gauge needle?
I have never done this and thinking about testing my GSR motor when it comes in and I get it installed. Thanks for any input!!
Old Jan 11, 2003 | 06:34 PM
KC GSR's Avatar
Default Re: How to do a Compression test? (Hybrid93Hatch)
The car doesnt actually start because you unplug the distributor...it just cranks
Old Apr 12, 2005 | 01:32 PM
PA MATT's Avatar
Default Re: How to do a Compression test? (KC GSR)
you can also unplug the ecu fuse as well, correct?
Old Apr 12, 2005 | 03:08 PM
turbodohcsi's Avatar
i thought you were suppose to leave the 3 spark plugs in the other cylinders that you werent testing, just loosen them up about 1 turn.
Old Apr 12, 2005 | 04:20 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (turbodohcsi)
i wouldnt really think the other 3 spark plugs matter that much... since your only worried about the cylinder with the tester on it
Old Apr 12, 2005 | 05:06 PM
N20civicB18's Avatar
Dont unplug fuel injectors, rather have someone hold the throttle wide open as the computer will go into clear flood mode so it will not inject fuel, plus it will make sure it sucks in the air it should.
If you have fuel dump into the cylinders that is like doing a wet test and will not tell you if your rings are bad. (depending how bad they are)
Old Apr 12, 2005 | 07:45 PM
PA MATT's Avatar
Default Re: How to do a Compression test? (N20civicB18)
what was that? if you hold the throttle down it wont tell you your true compression or am i reading that wrong?
Old Apr 12, 2005 | 07:47 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: How to do a Compression test? (PA MATT)
in order to due a proper "dry" compression test... unplug the dizzy and pull the injector clips. hook up the compression tester and have a buddy hold the car at wot, turn the car over a few times until the compression gauge needle stops moving.
if you dont hold the car at wot, the numbers wil be wrong. because the car will suffer from pumping losses
Old Apr 12, 2005 | 08:04 PM
PA MATT's Avatar
Default Re: How to do a Compression test? (wantboost)
ive always just unplugged the ecu fuse and then done it at wot, this is the wrong way of doing it?
Old Apr 12, 2005 | 08:14 PM
wantboost's Avatar
Who is Mr Robot?
well, if the ecu isnt getting power... then the car shouldnt be getting fuel, which means the test would be performed dry... so i guess its all the same, one just requires less effort than the other
Old Apr 12, 2005 | 08:21 PM
Bailhatch's Avatar
Yup ECU fuse is the fastest easiest way to kill spark and fuel. I have done lots of compression tests with the throttle plate closed and never really had any weird or low readings. I dont think the motor moves all that much air in 7 cranks or however many you are doing it to. But do as I say not as I do and keep the pedal floored while cranking. And makes sure all the spark plugs are out and the battery has a strong charge or is on a charger
Old Apr 13, 2005 | 07:03 AM
Muckman's Avatar
Moderator in Chief
Who the hell unplugges the dizzy and all 4 injectors when you can just pull one simple ECU fuse and be done with it.
How many Honda-Tech members does it take to change a light bulb?
Old Apr 13, 2005 | 07:58 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">Also how does this differ from a leak down test.</TD></TR></TABLE>
With a leakdown test, you bring one cylinder to TDC on the compression stroke and leave it there. You pull the spark plug and insert the tester. The tester will usually have two gauges - one for setting the input pressure (typically 100psi) and the other reads pressure lost. Because you're using 100psi input, a loss of 3psi will be equal to a 3% leakdown loss.
Old Apr 13, 2005 | 08:39 AM
FredoSP's Avatar
Default Re: How to do a Compression test? (EE_Chris)
lol guys this thread is OLDDDDDDDDD, lol my noob days.
anyways if someone wants I can provide a video for a compression test and leakdown, just let me know and I can help u out.
Old Apr 13, 2005 | 08:43 AM
Sonny's Avatar
lol...I was thinking to myself, "Damn, I can't believe Fredo is asking such a n00b question."
Old post
Sonny
