What bore piston in GSR block?
Old Dec 25, 2002 | 08:43 PM
speedy108's Avatar
Default What bore piston in GSR block?
It's a stock GSR block with 54,000 miles on it. Don't plan on sleeving it, just doing a quick hone. Is 81mm the bore piston I need to use, or do I need to go slightly larger?
What pistons do you guys recommend. JE or Arias or Wiseco? For turbo of course.
Thanks, Michael
Old Dec 25, 2002 | 11:34 PM
Flamenco-T's Avatar
Default Re: What bore piston in GSR block? (speedy108)
just stick with 81mm, or you can bore it out .50mm over and get 81.5mm. If you're not planning to take the block out, stick with 81mm, just do a 10-12 quick passes with honing stone and put a set of new pistons and rods...
you can get shelf pistons for either size, so either way it's cheaper
stan
Old Dec 26, 2002 | 06:51 AM
speedy108's Avatar
Default Re: What bore piston in GSR block? (Flamenco-T)
Thanks for the info. By the way I just noticed your Sig. about the guy that stole your car. When he gets out, **** him up bad for all of us.
Old Dec 26, 2002 | 07:16 AM
b18CT's Avatar
i know that 400 whp on stock 81mm sleeves is easy to get but if i bore it out to 81.5mm on stock sleeves whit some new j.e piston will it hold on 20 psi or 400whp whit succes?
Old Dec 26, 2002 | 07:37 AM
b18bturbo's Avatar
Default Re: What bore piston in GSR block? (REVTurbo)
it depends on how you tune it.. i seen the inline pro guys do it with there gasket but i havent seen many other guys sucessfully do it...
93delsolJDM
Feb 13, 2011 11:25 PM
BoOstedN1ck
Aug 8, 2009 05:22 AM
bjfisher
Aug 10, 2006 02:11 PM
evade this honda
Jul 28, 2006 07:20 PM
fastcivicboy
Mar 21, 2005 08:51 AM
