Best turbo cams?
Re: Best turbo cams? (J2turbo21)
I've been asking myself the sam question. I know that Skunk 2 being an all motor company actually makes b18 turbo cams. I just never seen any results or heard anything about them. One member of HT suggested for me to use on cam for the intake. Their exact quote was that turbos like that..
Re: Best turbo cams? (IMSTOCK)
I think if you did a search, most here seem to feel that GSR will do a fine job. Perhaps some cam gears to dial out a little over lap.
I'm probably going to use my ITR cams with gears.
-S
-S
I am a bad person
Re: Best turbo cams? (CzanSOHC)
i like the type r cams if you are not going to play with any cam timing. I hear the gsr's are as good or better if you play with the cam gears. I leave mine at 0 and run type r cams.they are pretty aggressive. i wouldnt run skunk or anything other than honda cams. They have the head figured out pretty good. Now if we could just get a cast iron solid deck block from the factory.
