keep the cams or no?
Old Dec 23, 2002 | 08:27 AM
rbf351's Avatar
Default keep the cams or no?
i used to be NA before i went turbo so i have a set of CTR cams in my Si
now should i pulled the CTR cams and put back my stock ones or GSR ones?
i tried the other night to rev to 8600(since i have the CTR ecu)like i normally do and the car didn't wanna go past 8000
Old Dec 23, 2002 | 10:50 AM
camp1320.com's Avatar
Default Re: keep the cams or no? (rbf351)
GSR if you can get them if hot put the SI back... youll be happy you did..
Old Dec 23, 2002 | 11:06 AM
rbf351's Avatar
Default Re: keep the cams or no? (camp1320.com)
should i also keep the CTR ecu or just go back to the stock Si ecu?
Old Dec 23, 2002 | 12:25 PM
DeepSi's Avatar
Most people will say the GSR Cams are better. second will be the Si cams.
Old Dec 26, 2002 | 06:19 AM
rbf351's Avatar
how bout the ECU?
keep it or no?
and what is the best rpm for the vtec crossover?
Old Dec 26, 2002 | 06:34 AM
tony1's Avatar
I would lose the ctr ecu. The timing curve on that is very aggressive, not good for turbo. With high compresssion and high octane fuel in Japan, they run alot more timing than you want to run in a turbo car!
Old Dec 26, 2002 | 06:37 AM
rbf351's Avatar
Default Re: keep the cams or no? (tony1)
so should i pull the ECU now? even though i still have the CTR cams in the car?
Old Dec 26, 2002 | 06:40 AM
tony1's Avatar
I would. The only this is if you put in a gsr ecu, there will be a dip in power when vtec kicks on. Try to get a us spec b16 ecu. Or just get a hondata or ems.
Old Dec 26, 2002 | 06:43 AM
rbf351's Avatar
i have my old Si ECu sitting in a closet
so i guess tonight i will put it back on
99ekb18b
Sep 12, 2008 08:55 PM
95egSi
Dec 5, 2004 02:41 AM
Option
May 18, 2004 10:17 PM
Blk95GSR
Sep 18, 2003 01:33 PM
IgniteTeg
May 19, 2002 12:23 AM
