Necessity of the following gauges?
Old Dec 23, 2002 | 11:44 PM
vtec.dc2's Avatar
Default Necessity of the following gauges?
What I plan to purchase:
1. Mechanical Boost
2. Electronic Oil Pressure
3. Electronic EGT
Can't decide if I need the following:
1. Fuel Pressure (currently have a manual on top of fuel filter)
2. Electronic Oil Temp - I'd think oil pressure is more important out of the 2, but what good will oil temp do?
Thanks
[Modified by vtec.dc2, 12:57 PM 12/24/2002]
Old Dec 24, 2002 | 07:24 AM
tygsr's Avatar
Default Re: Necessity of the following gauges? (vtec.dc2)
1. Manual Boost
3. Electronic EGT
Thanks
[Modified by vtec.dc2, 4:12 AM 12/24/2002]
First off I would get all electronic gauges. Second the boost, egt, oil press are very important, I would get a temp gauge over the other ones listed. Turbo cars tend to get a little hot if you know what I mean.
Old Dec 24, 2002 | 08:37 AM
vtec.dc2's Avatar
Default Re: Necessity of the following gauges? (tygsr)
thanks,
any other opinions?
Old Dec 24, 2002 | 08:49 AM
b16ahybrid's Avatar
1)boost
2)egt
3)oil pressure
Old Dec 24, 2002 | 08:54 AM
PM-Performance's Avatar
Default Re: Necessity of the following gauges? (b16ahybrid)
i have boost , egt, oil perss and a/f
and the fuel perss under the hood.
the only one i got mech is the boost becuase the price diff .
Old Dec 25, 2002 | 08:30 PM
vtec.dc2's Avatar
Wouldn't mechanical boost gauge be more accurate than electronic? Mechanical boost gauge (max 5psi) isn't as bad as oil pressure?
Also, some turbo times (for example blitz) offer boost reading - would that be as accurate?
[Modified by vtec.dc2, 12:31 AM 12/26/2002]
Old Dec 25, 2002 | 10:33 PM
RangerDan's Avatar
While we are on the subject. My set-up is an sohc 1.5 with a greddy kit...not yet installed, still trying to figure out the final details. For sure I am going mech boost,
most likely a/f gauge. Read a few things on the egt gauges but thought that on my
current set-up was a little overboard. Also my kit didn't come with injectors so at stock boost (5.5) I should be O.K. no? In addition I will be running a 6a MSD, test pipe and 2.5 inch exhaust. Thanks for any info.
Old Dec 27, 2002 | 03:04 PM
vtec.dc2's Avatar
1. Mechanical Boost
3. Electronic EGT
Any other opinions regarding fuel pressure and oil temp?
Old Dec 27, 2002 | 03:14 PM
drewspeed's Avatar
Although a bit more cumbersome to install, I'd go with a mechanical Oil Pressure gauge rather than an electronic. Just my .o2
http://www.theoldone.com/articles/oilpressure/ - this is the link I used to install mine.
Good luck
Old Dec 28, 2002 | 09:21 AM
vtec.dc2's Avatar
Default Re: Necessity of the following gauges? (drewspeed)
Good luck
thanks..
what about fuel pressure and oil temp? - can someone think of more reasons to have these? (I already have mechanical fuel pressure on top of fuel filter)
Old Dec 28, 2002 | 09:33 AM
ion_four's Avatar
Default Re: Necessity of the following gauges? (94hondahybrid)
I wouldn't get a mechanical oil pressure gauge...why run more oil lines (ESPECIALLY into the cabin) than you have to, it's just asking for trouble. I would, however, go with the mechanical boost gauge because it should be more accurate and will be MUCH cheaper than the electronic. The worst that could happen if it fails is that you have a vac./boost leak. I wouldn't really waste my money on the fuel pressure unless I was using an FMU (which is a waste of money, anyway) though, the oil temp would be good if you are itching to get another gauge
VTEC+Mini
May 27, 2012 12:42 PM
fishieman
Dec 10, 2008 10:43 PM
Alberto
Jan 30, 2004 05:51 AM
Boostless97Lude
Jun 18, 2003 08:42 AM
skhonda
May 8, 2003 09:16 PM
