obd0 Hondata question
Old Dec 24, 2002 | 02:55 PM
Timmayeg's Avatar
New User
Default obd0 Hondata question
ok i want to get hondata boost setup for my sohc turbo project in a 91 hatch. i know i have to convert to obd1, here is my question
what ecu, distributor do i need? i know where to get the obd0-1 harness so thats not a problem, im doing a d16a6 so there wont be any Vtec involved. and i do have a 94 CX ecu and distributor laying around will they work?
thanks and merry christmas
Old Dec 24, 2002 | 08:08 PM
Timmayeg's Avatar
New User
Default Re: obd0 Hondata question (91_ED6_Civic)
anyone?
Old Dec 24, 2002 | 08:37 PM
Spunkster's Avatar
You don't have to convert to OBD1. You can use the Stage 2 or 3 with OBD0. The s100 and s200 systems only work with OBD1.
Old Dec 24, 2002 | 10:16 PM
Timmayeg's Avatar
New User
Default Re: obd0 Hondata question (Spunkster)
im staying with the d16a6 not dohc vtec, i want one that has the boost option
Old Dec 25, 2002 | 11:56 AM
Timmayeg's Avatar
New User
anyone else?
Old Dec 25, 2002 | 12:23 PM
mos's Avatar
mos
You can use an OBD-0 ECU from a vtec car (JDM integra xsi or crx siR) and hondata 3b it. OBD-0 works with boost, but not datalogging. Just because the ECU supports vtec doesn't mean you have to use that feature. I'm sure you can get the PR3 or PW0 to work fine with your sohc non-vtec motor.
If you want to convert your car to OBD-1 for hondata, you might be able to use a non-vtec ECU from a DX or something. Hondata's website should have information on this. You might want to check there or call them.
[Modified by mos, 1:27 PM 12/25/2002]
Old Dec 25, 2002 | 02:26 PM
Timmayeg's Avatar
New User
Default Re: obd0 Hondata question (mos)
yea i want data logging, i have a p05 i think it is, CX ecu i wonder if that will work
Old Dec 25, 2002 | 04:22 PM
Jefnes's Avatar
You can use a PW0 or PR3 for ALL your needs. Datalogging, 3 bar map sensor ect.
You just a have to use the 'older' version of their software. Not a big deal.
All the features you need to tune the car properly are there.
I tuned a PW0 on a '89 JDM B16A turbo to 333 whp. Piece of cake.
Hondata's website lists what ECU's they work with.
Jeffrey Atwood
Old Dec 25, 2002 | 06:55 PM
RAWB's Avatar
Default Re: obd0 Hondata question (Jefnes)
So you can datalog on an OBD0, then?
Old Dec 25, 2002 | 07:26 PM
Timmayeg's Avatar
New User
Jeffrey Atwood
so what hondata setup would i use with one of these ecu's? i just want to be able to tune it , and i want to be able to datalog
Old Dec 25, 2002 | 08:12 PM
racerxadam's Avatar
you can datalog sensors with an obd-0 ecu but not the o2 sensor specifically. at least thats what I and a few others with obd-0 hondata setups found
Old Dec 25, 2002 | 08:33 PM
Timmayeg's Avatar
New User
Default Re: obd0 Hondata question (racerxadam)
so what does that mean?
Old Dec 25, 2002 | 08:42 PM
racerxadam's Avatar
it means there is a ground loop problem somewhere in the factory wiring that causes the ecu to get false readings from a wideband. subsequently making it very difficult to log a/f ratios v. thier position on the fuel map.
Old Dec 25, 2002 | 08:45 PM
Timmayeg's Avatar
New User
so whats needed to solve this? i want to be able to tune it the best i can,
is it gonna be better for me to go obd1 or stay obd0? i want it to be the best i can get it
Old Dec 26, 2002 | 12:19 AM
racerxadam's Avatar
I got fed up trying to figure out a way around it but decided to use the aem ems instead. it has a gain function that allows you to manipulate what the ems reads as the actual voltage coming from the wideband. true and I think it was slowteg had the same problem as I did and I don't know if they have figured it out.
Old Dec 26, 2002 | 12:31 AM
Timmayeg's Avatar
New User
i think im pretty sure im going obd1 and sticking with hondata, im sure it will be worth it in the long run
Old Dec 28, 2002 | 06:58 PM
Spunkster's Avatar
You can use either, but tuning will be much easier with OBD1. Give me a call on Monday and YOu can get enyother questions answered. Number is on our website.
www.hondata.com
gian_ed7b16a1
Feb 12, 2016 04:09 AM
SiRex91
May 8, 2003 07:10 AM
dalepatters
Feb 14, 2003 02:48 PM
C4wrx
Aug 9, 2002 12:00 AM
