Clocking turbo, no compressor bolts...
Old Dec 23, 2002 | 05:28 PM
JalopySiR's Avatar
Default Clocking turbo, no compressor bolts...
I am wondering how to clock a turbo with no bolts on the compressor side. There are 4 bolts on the turbine side. It is a T-25 Garret. Not a DSM turbo. The other problem is, after clocking the turbo so that the compressor outlet faces down, the wastegate will not work as it was. Can I redrill holes onto the compressor to mount the wastegate? Thanks for any help you can provide me with.
Old Dec 23, 2002 | 06:09 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Clocking turbo, no compressor bolts... (JalopySiR)
i had the same problem with my td04. i was ghetto and actually zip tied it to the a/c line going down, it actually stayed put and worked well. you could also JB weld it onto the compressor, or drill some shallow holes onto the compressor.
Old Dec 23, 2002 | 08:58 PM
JalopySiR's Avatar
Default Re: Clocking turbo, no compressor bolts... (rewsnaeht)
The wastegate problem is solved. One of those suggestions will be used. or Abaz' spring technique. The other problem is when I finally do rotate the turbine, the oil lines won't line up properly... Is there any way to clock the compressor side of this wacky small turbo? There has to be a way, It has to be put together somehow...
Old Dec 23, 2002 | 10:04 PM
E-Rok's Avatar
EPIC TUNING
there is nothing you can do about the oil lines unfortunately.
Old Dec 24, 2002 | 12:41 AM
kinesistech's Avatar
There is a snap ring on the back of the compressor housing, you need big snap ring pliers and a friend. Just take off the compressor housing. Once you figure your positions, mark, drill and tap your wastgate holes. Be sure to clean the housing before reassembly. Use prematex thread sealer on the bolts.
Old Dec 24, 2002 | 10:20 PM
JalopySiR's Avatar
Default Re: Clocking turbo, no compressor bolts... (kinesistech)
Thanks, I will do that.
Superdragr45
Sep 26, 2004 10:57 PM
youngkow
Jan 3, 2003 12:03 PM
sutrusu
Aug 21, 2002 03:33 PM
ezark
Jun 13, 2002 11:09 PM
