MAP senser...can i throw it away?
Old Dec 21, 2002 | 04:36 PM
turbohf's Avatar
Default MAP senser...can i throw it away?
k, i have a GM 2 bar map senser and want to install it (88 CRX HF, Zdyne SECU Gold). so im going to be unplugging the honda map, so i want to clean up a little and toss it...but there are a coule other little purge valves or some **** hooked up with all that with vaccum lines. the vaccum line arent hooked up and havent been...ever. so anyway they have a 4pin connector on them, can i toss those too??? thanks
Old Dec 21, 2002 | 07:33 PM
Speed PHreak's Avatar
Default Re: MAP senser...can i throw it away? (turbohf)
Ummm clarify that a bit more for me but, from the gist I got is that you want to use the 2 Bar GM MAP and toss your stock MAP sensor. You can toss it if you want. I'd leave the stock plug and just splice into the wiring, so you can go back and use the stock setup if need be....
Also leave the purge valves, the work from your emissions stuff, help your gas milage and prolly would make the ECU(even your Zdyne) throw a code if you chunked 'em.
Just FYI, i've got a Zdyne SECU gold and use a GM 2 bar MAP as well
[Modified by Speed PHreak, 11:34 PM 12/21/2002]
Old Dec 21, 2002 | 08:55 PM
turbohf's Avatar
Default Re: MAP senser...can i throw it away? (Speed PHreak)
emissions? whats that???
https://honda-tech.com/zerothread?id=365737
turbosohcabortion
May 17, 2007 07:40 PM
Smashback
Jan 27, 2003 03:33 AM
turbohf
Dec 21, 2002 07:11 PM
