anyone using a drag2 kit on a 97+ prelude?
Old Dec 26, 2002 | 06:11 AM
Wo-Nelly's Avatar
Default anyone using a drag2 kit on a 97+ prelude?
Could you tell me how your setup is going? What kinda #'s are you putting down at what psi? I can't seem to make good gains even when i raise the boost.
Old Dec 26, 2002 | 06:50 AM
BlueShadow's Avatar
Default Re: anyone using a drag2 kit on a 97+ prelude? (GottaLude)
Are you turboed right now? what is your current setup and HP numbers?
Old Dec 26, 2002 | 10:55 AM
Wo-Nelly's Avatar
Default Re: anyone using a drag2 kit on a 97+ prelude? (BlueShadow)
224@6psi
Old Dec 26, 2002 | 11:13 AM
BlueShadow's Avatar
224@6psi
what's your current setup? what kit is it (DRAG 2 right?), compressor and turbine trim, exhaust diameter, DP size, fuel setup, etc etc.
If we know what you got maybe we can help tell you what parts you need to upgrade or replace to make more power.
[Modified by BlueShadow, 12:17 PM 12/26/2002]
Old Dec 26, 2002 | 11:35 AM
Wo-Nelly's Avatar
basic drag2 kit, aem ems, 550cc injectors, and tial wastegate. Thats mostly it
Old Dec 26, 2002 | 11:52 AM
BlueShadow's Avatar
-does you WG dump back into the exhaust or to the atmosphere?
-3" exhaust system, from where the DP curves around the bottom all the way to the exhaust tip.
I plan on getting a 2.5" DP that flares to 3" once it's rounded the bottom of the engine. Then I'll also have a 3" flex-section, 3" cat, and 3" SS catback with an 80mm Apexi N1 muffler.
-would you happen to know what compressor trim or turbine A/R you have?
-have you tried raising the boost to 7 or 8 PSI? You may have seen Quualude's dynos, where he dynoed at almost 260 WHP with an AEM EMS and I think a T04E 60 and .63 a/r stage III turbine.
Old Dec 26, 2002 | 06:56 PM
Wo-Nelly's Avatar
-wg dumps into the atmosphere.
-the dp is what came with the kit, but it turns in to 3" all the way back once it clears the oil pan.
-The turbo is what came with the kit. I think it is a t3/t40b with a 0.63 a/r not positive tho
-I ran it on the dyno at 8psi but only made 228
Old Dec 27, 2002 | 02:10 PM
Wo-Nelly's Avatar
anyone at all?
Old Dec 27, 2002 | 02:23 PM
BlueShadow's Avatar
The turbo trim might be your problem, Quualude (who made 260ish WHP) and most other people are running T04E's in either 57 or 60 trim (w/ .63 stage III turbine). I myself am running a T04E 60 but with a .63 stage II turbine.
see what everyone ele has to say about your turbo trim though.
Old Dec 27, 2002 | 04:25 PM
Wo-Nelly's Avatar
are you running a drag2 kit?
i don't understand how it is the turbo's fault. I don't know a lot about compressor maps and efficiency but I don't how 8psi is going to be out of the turbo's efficiency range.
Old Dec 27, 2002 | 05:29 PM
BlueShadow's Avatar
I have a custom kit that I just bought, so it's not installed yet. Try comparing your HP numbers with other people that have a T04B and similar setup.
Old Dec 28, 2002 | 08:40 AM
Wo-Nelly's Avatar
appearently no one's running a drag2 kit on the same car
Old Dec 28, 2002 | 08:46 AM
BlueShadow's Avatar
well it doesn't necessarily have to be a Drag 2...just try comparing someone with the same turbo specs. Also try to research the Drag 2 manifold, maybe it's more restrictive than the other manifolds.
Old Dec 28, 2002 | 08:49 AM
PrecisionH23a's Avatar
You should be putting out way more then 228@6psi. A buddy of mine has essentially the drag gen 2 on his h23a with a rev hard manifold/downpipe and he is putting out 250whp @7psi. The t04b with a .63 ar should be capable of putting out well over 300whp, i think your problem lies in your dyno tuning. can you post a picture of your dyno chart and a/f ratio?
2slicc
Dec 5, 2012 02:23 PM
FullRaceEH2
Apr 3, 2005 06:53 PM
Rah Rah
Apr 2, 2003 04:46 AM
Sh4rky
Feb 9, 2002 08:36 AM
meanteg
Dec 11, 2001 07:23 PM
