Intercooler piping?? what size??
Old Dec 25, 2002 | 08:41 PM
DIY_Racing's Avatar
Default Intercooler piping?? what size??
What size intercooler piping should someone run... 10psi system. FMIC. is 2 inch enough???
Thanks.. Want opinons from the turbo peeps
Old Dec 25, 2002 | 08:46 PM
shortyz's Avatar
Default Re: Intercooler piping?? what size?? (DIY_Racing)
well the throttle body is 2 1/2. so anything bigger is useless..
unless u got a bigger tb depending on your engine
Old Dec 25, 2002 | 09:15 PM
ninesecrx's Avatar
If you plan to run 10 pounds max, 2" is fine. You can go the safe route though and make it 2.25...that would even make it worth more for a resale thing some day.
Old Dec 25, 2002 | 11:39 PM
lilxvtecxpwr's Avatar
Default Re: Intercooler piping?? what size?? (ninesecrx)
alot of people run 2" piping from the compressor to the intercooler, then 2.5" from intercooler to the throttle body.
but 2" should be fine @ 10psi
Old Dec 25, 2002 | 11:43 PM
Flamenco-T's Avatar
Default Re: Intercooler piping?? what size?? (lilxvtecxpwr)
I'll vote for 2.25 " perfect median for pressure and volume IMO..
stan
Old Dec 26, 2002 | 12:13 AM
Jdm_Rice_Monster's Avatar
Default Re: Intercooler piping?? what size?? (Flamenco-T)
I used 2.25 piping on my custom kit, but I heard it would benefit me to run 2.5 on the pipe that runs to my t.b. has anyone done that and had sucsess or is it not worth the hassel of changing it.
Old Dec 26, 2002 | 01:17 AM
dave'sh22a4's Avatar
Default Re: Intercooler piping?? what size?? (JdmRiceMonster)
i don't think 2.5" to your tb is a good idea i think 2.25" should be the best for 10psi...more the 15psi should use 2.5"
Old Dec 26, 2002 | 07:17 AM
KC GSR's Avatar
Default Re: Intercooler piping?? what size?? (dave'sh22a4)
if your piping is 2.25 and your tb is 2.5, what kind of coupler can you use to connect the two? I need to find something quick that will fit both sides
Old Dec 26, 2002 | 07:24 AM
BlueShadow's Avatar
Default Re: Intercooler piping?? what size?? (KC GSR)
https://honda-tech.com/zerothread?id=368374
https://honda-tech.com/zerothread?id=368331
Old Dec 26, 2002 | 08:35 AM
mos's Avatar
mos
Default Re: Intercooler piping?? what size?? (BlueShadow)
You can just buy a cheap rubber coupler from Home-Depot. The one that might fit is the 1 1/2" to 2" coupler for thick galvanized steel sewer pipe. It fits on my 2" to 2 1/2" and 2 1/2" mates up to my TB perfectly. You should be able to stretch it to fit onto a 2 1/4" pipe. Take your pipe to the store if you want to test it out. It comes with hose clamps for like 3$, but it is not heat rated, so you can take your chances there. I've seen a bunch of people using it also in their ghetto turbo picts though.
Old Dec 26, 2002 | 08:43 AM
AVATAR's Avatar
are most TB inlets 2.5"?
Old Dec 26, 2002 | 08:59 AM
camp1320.com's Avatar
Default Re: Intercooler piping?? what size?? (AVATAR)
2inch from turbo to intercooler and 2 1/4 from intercooler to TB is perfect for street combos.. you get quicker spool up due to the less volume of compressed air is needed to fill the pipes.. i have personally seen 400hp+ on street cars running this set up... 2 1/4 all the way is fine too...
jbell
Nov 15, 2008 12:54 PM
1990hondaHF
Aug 16, 2006 10:17 PM
Sinner
Oct 13, 2003 11:30 AM
dmecarboy
Aug 8, 2003 05:55 AM
HuskerHybrid
Jul 10, 2003 11:38 AM
